![]() | Home > Puma (Tdci) > Puma 2.2 and 2.4 Defenders. |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1003 ![]() ![]() ![]() |
Each to their own but it’s probably people chasing the latest ones possible. Tax is probably another thing with that old debate.
2.4 for me, personally - just because there’s no DPF. The later ones seem to be rusting quicker also. Whether that’s because JLR knew they were ending production so cut back on corrosion protection etc (money saving) There’s no right answer. I’d just buy the best example for your budget. I’d save £10k and buy the low mileage 2.4 and leaves money to improve it. There’s no noticeable difference between engine output/delivery. 2008 2.4 110 Utility Station Wagon XS. |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 674 ![]() ![]() ![]() |
Having run both, I tend to prefer the 2.4,
If maintaining the vehicle yourself there engine bay is not quite as jam packed, the 2.2 always seems like they just jammed the lot in and started cutting the bulkhead until they got clearance or the DPF. There’s also some cost cutting and strange decisions. The late bulkhead hinge captive nuts for example are now causing problems causing rust (just worked on a 2015 with a gaping hole in bulkhead pillar above the bottom hinge). Cheap centre diff, going back to 2 pin diffs in front of 110 etc. Going from 2.2 into 2.4 the 2.4 does seem slightly less refined but more “Land Rover” |
Can’t comment on a 2.2, but what I can say is 2.4 related, and I’m glad there isn’t a DPF. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 965 ![]() ![]() ![]() |
I run a 2.2 90 and it doesn't miss a beat.
I've also had a 2.4 which was also great. Out of the 2 the 2.2 does feel that it drives better but this could all be psychological and nothing more than the 2.2 being a newer vehicle. The 2.4 was rust proofed by a previous owner using a company that specialises in Defenders using Dinitrol. I was surprised that there wasn't more of an attempt by Land Rover to rust proof the 2.2 better, particularly the rear wheel arches? A| lot of 2.2's appear to be "Garage Queens" with folk buying them as an investment that they only take out at the weekend in good weather? Mine is a very usable daily drive. Jim |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
some 2011 2.4s avoid the higher tax DEFENDER 90 TDCI XS,
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 252 ![]() ![]() ![]() |
I happily run a 2.4. That said, 2.4s are just older. Things deteriorate over time so any 2.4 is likely to have more issues (hopefully minor) than a 2.2. Simple math.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3236 ![]() ![]() |
Well, l am still looking.
l will take a 2.2 or a 2.4 so long as it isn't in the £700 road tax category. |
revd Member Since: 20 Apr 2024 Location: England Posts: 269 ![]() ![]() |
Go with what you know and buy another Td5
l would, if l could find a decent 110 XS, there's plenty of TDCi's but not seen any TD5's
But also the TDCi would be better for business use. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2021 ![]() ![]() ![]() |
i prefer the 2.4 which is personal preference really, appearance can be altered but service history and maintenance can't, buy the best looked after and then start your journey customising and upgrading
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3796 ![]() ![]() ![]() |
A major plus, hear in Ausiie at least, is that the 2.2 has the 6 speed gearbox, making for much more relaxed engine revs when cruising.
So does the 2.4. All pumas had the 6 speed.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1280 ![]() ![]() ![]() |
It seems that while newer cars typically would fetch higher prices because of less wear, miles, rust, etc. often you find that in terms of cost of ownership and future hassle the older models are more preferred as they are simpler, typically less to go wrong and cheaper parts and good support in general, assuming of course they are well maintained in the first place and not some sort of old beater.
2.2 -> 2.4 -> Td5 -> 300/200tdi. Personally I think the Td5 is the sweetspot (with an overdrive), but its a personal preference. I have other diesels (Sdv6) and they are just overly complicated and potential money pit. Obviously local restrictions with emissions IS an important consideration, but if that is a important for you go for something PETROL (I know limited options in Defender land) - even the cleanest diesels are facing restrictions everywhere. |
Thanks for that, I didn't know! |
