Home > Puma (Tdci) > Puma 2.2 and 2.4 Defenders.
lightning
l've been looking for a Puma 110 and have noticed that the 2.4 version seems a lot cheaper than the 2.2 even if it's a really nice example.
For instance l was looking at a 2015 2.2 last week advertised at £32,995 and l've just seen a 2010 2.4 in similar condition at £21,995.
Also the very low mileage (under 10,000) 2.2' SW's seem to sell at £40,000+ but there's been a 2007 3,600 mile 2.4 XS 110 SW on sale for over 12 months initially at £39,995 and now £35,000 and it's still not sold.
l thought there wasn't much difference between the two, in fact a dealer in Macclesfield told me the 2.2 "lacks torque" and the 2.4 is better.
Post #1068850 31st May 2025 7:22pm
BrickBox
Each to their own but it’s probably people chasing the latest ones possible. Tax is probably another thing with that old debate.
2.4 for me, personally - just because there’s no DPF.
The later ones seem to be rusting quicker also. Whether that’s because JLR knew they were ending production so cut back on corrosion protection etc (money saving)
There’s no right answer. I’d just buy the best example for your budget. I’d save £10k and buy the low mileage 2.4 and leaves money to improve it.
There’s no noticeable difference between engine output/delivery. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1068852 31st May 2025 8:44pm
Oldowner
Having run both, I tend to prefer the 2.4,
If maintaining the vehicle yourself there engine bay is not quite as jam packed, the 2.2 always seems like they just jammed the lot in and started cutting the bulkhead until they got clearance or the DPF.
There’s also some cost cutting and strange decisions. The late bulkhead hinge captive nuts for example are now causing problems causing rust (just worked on a 2015 with a gaping hole in bulkhead pillar above the bottom hinge). Cheap centre diff, going back to 2 pin diffs in front of 110 etc.
Going from 2.2 into 2.4 the 2.4 does seem slightly less refined but more “Land Rover”
Post #1068854 31st May 2025 9:50pm
Can’t comment on a 2.2, but what I can say is 2.4 related, and I’m glad there isn’t a DPF. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1068855 31st May 2025 9:57pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
I run a 2.2 90 and it doesn't miss a beat.
I've also had a 2.4 which was also great. Out of the 2 the 2.2 does feel that it drives better but this could all be psychological and nothing more than the 2.2 being a newer vehicle.
The 2.4 was rust proofed by a previous owner using a company that specialises in Defenders using Dinitrol. I was surprised that there wasn't more of an attempt by Land Rover to rust proof the 2.2 better, particularly the rear wheel arches?
A| lot of 2.2's appear to be "Garage Queens" with folk buying them as an investment that they only take out at the weekend in good weather? Mine is a very usable daily drive.
Jim
Post #1068867 1st Jun 2025 4:58am
LR90XS2011
some 2011 2.4s avoid the higher tax DEFENDER 90 TDCI XS,
Post #1068870 1st Jun 2025 7:35am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
I happily run a 2.4. That said, 2.4s are just older. Things deteriorate over time so any 2.4 is likely to have more issues (hopefully minor) than a 2.2. Simple math.
Post #1068884 1st Jun 2025 2:38pm
lightning
Well, l am still looking.
l will take a 2.2 or a 2.4 so long as it isn't in the £700 road tax category.
Post #1068939 2nd Jun 2025 12:52pm
revd
Go with what you know and buy another Td5
Post #1068940 2nd Jun 2025 1:00pm
lightning
l would, if l could find a decent 110 XS, there's plenty of TDCi's but not seen any TD5's
But also the TDCi would be better for business use.
Post #1069384 10th Jun 2025 12:26am
bear100
i prefer the 2.4 which is personal preference really, appearance can be altered but service history and maintenance can't, buy the best looked after and then start your journey customising and upgrading Very Happy 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1069387 10th Jun 2025 7:17am
Pickles
A major plus, hear in Ausiie at least, is that the 2.2 has the 6 speed gearbox, making for much more relaxed engine revs when cruising.
Post #1069459 11th Jun 2025 12:00am
jbcollier
So does the 2.4. All pumas had the 6 speed.
Post #1069461 11th Jun 2025 12:57am
TexasRover
It seems that while newer cars typically would fetch higher prices because of less wear, miles, rust, etc. often you find that in terms of cost of ownership and future hassle the older models are more preferred as they are simpler, typically less to go wrong and cheaper parts and good support in general, assuming of course they are well maintained in the first place and not some sort of old beater.
2.2 -> 2.4 -> Td5 -> 300/200tdi. Personally I think the Td5 is the sweetspot (with an overdrive), but its a personal preference. I have other diesels (Sdv6) and they are just overly complicated and potential money pit.
Obviously local restrictions with emissions IS an important consideration, but if that is a important for you go for something PETROL (I know limited options in Defender land) - even the cleanest diesels are facing restrictions everywhere.
Post #1069467 11th Jun 2025 6:12am
Pickles
Thanks for that, I didn't know!
Post #1069549 11th Jun 2025 11:52pm
