![]() | Home > General & Technical (L663) > 26MY Updates |
| J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3493
Not sure about the Tetris inspired bonnet graphic
Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
| L3785 Member Since: 08 Oct 2024 Location: Yorkshire Posts: 57
I know these things are subjective but I like the way they’ve approached this update.
It was about time they made some tweaks but they’ve done it without making big changes that will make my six-month old 90 look outdated. So many manufacturers make huge changes when they facelift a model that instantly dates the outgoing one. Personally, I think the new screen size isn’t needed (and could be even more challenging to use behind the gearstick) and the updated ‘grips’ on the side of the bonnet don’t look as good as the current model. However, the smooth tail lights look great and the small update to the wheel hubs are a success (and I might treat myself to those!) 2025MY Defender 90 D250 X-Dynamic HSE | Santorini Black with Black Pack |
| Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 210
does this detect if you shut your eyes/ fall asleep?? |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3325
l wonder if the new rear lights can be retrofitted to the old model. Come on Powerful U.K. let's see another one of your Youtube videos!
They've already tried to fit an Octa grille....it didn't fit. |
| XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 545 |
Where are my spiders going to sit now!? And is it just me.. or at a squint, does that look like two, very lo-fi fists with middle fingers sticking up!??
| WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 178
Mine prefer the inside of the spare wheel carrier. Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
| Oneblack Member Since: 14 Oct 2024 Location: Here Posts: 35
I take that back, on some newly released images the old air suspension buttons can clearly be seen.. |
I have the optional mirror dwelling spiders. 24MY 90 D250 HSE, Tasman Blue |
| supulasti Member Since: 26 May 2025 Location: Bremen Posts: 4
Ordered mine on monday, release of the new model was on wednesday... wrote my dealer to upgrade/change my order. I hope he can do that
If you only ordered on Monday then your order will be a 26MY 24MY 90 D250 HSE, Tasman Blue
Is that for sure? I just looked it up and yes, my order was on monday, 26.05.
| Landy240 Member Since: 22 Jul 2024 Location: Merseyside Posts: 28
When you place an order (in the UK at least) it goes into a 'pool' where it waits until it is picked up and assigned a build slot.
If you have not been assigned a build slot before the MY change then you will certainly get the new model year. My order took so long to be picked up that the model year changed and many of the options I had chosen were no longer available. I then had to start again! |
Well, it's an option you don't have to tick. |
