Home > Maintenance & Modifications > Front Door Glass - jumped out of track
Avelingporter
I have had this once before.....on switching the front door glass to up, it seems to have jumped out of the track on the front edge and now sits to far towards the outer face of the door. Eventually it gets stuck on the rubber at the forwards end. The result being it wont go the last 3" or so to the top.
I have had this before and took the door card off and managed to gemmy it back in to the track, but was a bit of force required.
So how do I do this more easily and is there anything I need to adjust to stop it happening again?
FYI 2016 90 2.2 hard top, electric windows....
Thanks AP
Post #1068627 28th May 2025 4:47pm
Lube up everything there with white lithium grease, except the track of course and the glass edge, there probably is a few fixings that a bit loose at the lower edge, I seem to remember there is a foamy or rubber like edge that keeps it in place with some bolts, they might need slightly re-tightening (just a little Exclamation ), or a couple of minor parts replacing there.
It shouldn’t happen at all really, but annoyingly the best way of getting at it is behind the door card, but equally if you wanted to fit some sound proofing there, then it’s an ideal time to do these multiple jobs at once.
You can quite easily go around with door cards off anyway, if you are short of time, so long as the other “furniture” is in place such as handles etc, but go very easy taking the door cards off as the parts to the rear can snap, but they won’t with careful use of trim tools to pop each one off.
IIRC Blackwolf on here likely knows a lot about the elec window system and the issues you are talking about, I remember looking at them myself on mine, but you’ll need to identify exactly what is up with yours, it’s obviously loose or missing parts there, causing the issue.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1068659 28th May 2025 10:51pm
Oldowner
There are rectangular alloy shims which space the window track in, usually a stack of two or three at the bottom of the window track. I’ve had a 2015 which had no shims fitted so window glass was loose fit in sliders.
Post #1068853 31st May 2025 9:39pm
