![]() | Home > Puma (Tdci) > Are these cracks in the plastic? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
Just like mine.
Usually the gear lever knob is the one that cracks first. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 264 ![]() ![]() ![]() |
Mine looks exactly the same. I tried to hide the cracks with boot polish but it didn't work. 1953 80"
1987 mini city e 2011 90" |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3641 ![]() ![]() ![]() |
Something else to look forward to
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1068 ![]() ![]() ![]() |
Is this caused by sun exposure? Mine is garaged when not being driven and all the plastic is fine.
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 589 ![]() ![]() ![]() |
Mine is in a garage all the time as well - I drive it maybe once or twice a month, the rest of the time, it's kept inside. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
Maybe painting over? Not sure… “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2508 ![]() ![]() |
Have it and the rest of the dash re trimmed with leather
Probably cheaper to replace the part (part# FDS500040PUYB) though!
It's just cosmetic... so I'll just leave it, I guess. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
To me they are stress marks rather than UV degradation. Have you checked the bolts if they are perhaps over tightened? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I'll check, but they have never been undone, so this is from factory. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Upon further inspection I doubt this could be caused by the bolts, there is a metal spacer inside so the plastic is not under stress. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Looks like I managed to make it disappear, or close enough...
I applied some black bumper restorer on the cracks, to hide them. ![]() Click image to enlarge Quite happy with the result! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks - something else for me to worry about. Along with the white gunk taking over the rear loadspace, the rust on the bonnet and the rust where the corner cappings were redone 2 years ago. |
