![]() | Home > Maintenance & Modifications > How to remove a puma aerial antenna? |
| belgianchap Member Since: 01 Mar 2025 Location: East-Flanders Posts: 17
I am replacing it anyway so I will whack it in the morning and see what happens
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274
The more I think about it if you’ve loosened the retaining ring then it’s probably just stuck and may need a ‘whack.’ The lower clip won’t be stopping anything which is contrary to what I originally thought 🤪 |
Yes it does come out from underneath 👍 |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
Yeah, that’s just a support clip, but worth knowing that it is there though. ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 983
Another 10 minute simple job on a Defender that ends up taking hours, possibly days.....
Jim |
| andy63 Member Since: 30 Jun 2023 Location: north east Posts: 815
only photo I can find , but it doesn't show the underside of the wing , just the location of the antenna case in the clip..I think at the time I was more interested in the air intake on the inside of the wing..
Click image to enlarge |
good news lads.
Step 1 (failure): whackin it surprisingly didn't work Step 2 (success): pry up the rubber gasket looking thing on top and snip it with cutters until I could cut it entirely, after which I could yank the gasket out with pliers. Bam, it fell down. At this point, I'm still not sure what caused that stupid nut to be stuck but I am just going to move forward. |
The gasket in question
Click image to enlarge How the aerial came out Click image to enlarge Picture of the new aerial for fun Click image to enlarge |
Well we all live and learn.
Glad you got it sorted. The replacement looks splendid - but now you’ve lost your Defender height gauge…🤪 Thanks for sharing the outcome for the benefit of others. Lovely Defender |
Thanks! I really should do a photoshoot moment and share it with the forum. I got this car from and old hunter and I had to a full interior strip and upgraded a lot. I am going for a OEM+ sort of setting with a 'more money than common sense' kinda attitude.
(not turning it into a KHAN monstrosity though, outside only has very minor cosmetic upgrades such as black grill instead of silver) |
Glad that you managed to get it off, typical Puma style, these things can take longer than expected.
The new one looks good, I have the same I expect quite a lot of others do as well. ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
