Home > Maintenance & Modifications > How to remove a puma aerial antenna?
Page 2 of 2 <12
belgianchap
Belgium 2008 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
I am replacing it anyway so I will whack it in the morning and see what happens
Post #1067841 15th May 2025 8:32pm
When you put the pliers on it, is it only that piece that spins, or the other pieces on the top too?
If it still keeps going round just try and lift it up and away it might be out of its threads but stuck on the top, then there is the ring just below, then the plastic one below that to the wing.
If I remember rightly the antenna comes out from under the wing, not up through it.
It could have got seized, underneath, and broke away from the casing internally.
If it’s still stuck, then though a pain you might have to sacrifice the antenna, and drill / carefully dremel grind it out from the centre at the top, taking care to protect surrounding paint.
The aim then would be to get it out without damaging the wing at all or bending it.
They are known to occasionally seize, so this could be what has happened.
If you are happy to sacrifice it, I’d extend the antenna, cut it off at its lowest then push it in.
If you’ve got a cone drill bit, drill out the centre top cap with it, then it should all come out.
It’s only really that top piece that holds it on, the rest is all below. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067842 15th May 2025 8:35pm
Screbble
Thumbs Up
The more I think about it if you’ve loosened the retaining ring then it’s probably just stuck and may need a ‘whack.’
The lower clip won’t be stopping anything which is contrary to what I originally thought 🤪
Post #1067843 15th May 2025 8:35pm
Screbble
If you are happy to sacrifice it, I’d extent the antenna, cut it off at its lowest then push it in.
Yes it does come out from underneath 👍
Post #1067844 15th May 2025 8:36pm
Screbble wrote:
Thumbs Up
Yeah, that’s just a support clip, but worth knowing that it is there though. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067845 15th May 2025 8:40pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Another 10 minute simple job on a Defender that ends up taking hours, possibly days.....
Rolling with laughter
Jim
Post #1067871 16th May 2025 6:31am
andy63
only photo I can find , but it doesn't show the underside of the wing , just the location of the antenna case in the clip..I think at the time I was more interested in the air intake on the inside of the wing..
Post #1067875 16th May 2025 7:29am
belgianchap
good news lads.
Step 1 (failure): whackin it surprisingly didn't work
Step 2 (success): pry up the rubber gasket looking thing on top and snip it with cutters until I could cut it entirely, after which I could yank the gasket out with pliers. Bam, it fell down.
At this point, I'm still not sure what caused that stupid nut to be stuck but I am just going to move forward.
Post #1067877 16th May 2025 7:48am
belgianchap
The gasket in question
How the aerial came out
Picture of the new aerial for fun
Post #1067878 16th May 2025 7:53am
Screbble
Well we all live and learn.
Glad you got it sorted.
The replacement looks splendid - but now you’ve lost your Defender height gauge…🤪
Thanks for sharing the outcome for the benefit of others.
Lovely Defender Thumbs Up
Post #1067879 16th May 2025 7:59am
belgianchap
Thanks! I really should do a photoshoot moment and share it with the forum. I got this car from and old hunter and I had to a full interior strip and upgraded a lot. I am going for a OEM+ sort of setting with a 'more money than common sense' kinda attitude.
(not turning it into a KHAN monstrosity though, outside only has very minor cosmetic upgrades such as black grill instead of silver)
Post #1067895 16th May 2025 10:30am
Glad that you managed to get it off, typical Puma style, these things can take longer than expected. Rolling Eyes
The new one looks good, I have the same I expect quite a lot of others do as well.
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067975 17th May 2025 5:48pm
Page 2 of 2 <12
