![]() | Home > My Defender > Not my G4 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11043 ![]() ![]() |
A few little jobs to keep you going on the 90
![]() What is the bar that goes across the back above the rear door please ? Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Looks good, the accessories are actually worth quite a lot in their own right so that’s a positive and a good buy in my opinion.
![]() ![]() With the diff pinion seal leak, is that the front or the rear? Hope you don’t mind me asking. Only, sometimes they can be worn elliptical and cause a leak like that, and the seal and pinion then needs replacing. My reason for mentioning this, was I had this happen before, but found the leak came back. The cause was the nearest Prop UJ, needed replacing as one of the bearing cups, roller bearings had gone. So that caused an uneven load on the pinion via the prop, and that then caused the other issues. You’d have thought that’d be checked, but it wasn’t, so the UJ’s were at fault causing that. So might be worth checking that, especially the UJ nearest the leak, and that grease nipples are present as well. Only, if it is a UJ, and you replace the pinion and seal, it will leak again due to that. To add to the fun, they can be quite difficult to find the play in the UJ’s in situ, but you can normally tell. You probably know a lot about these things anyway, but worth bearing in mind as I’ve seen that be an issue first hand so that might be worth checking as well. Looks a good buy anyway. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Joncorry Member Since: 03 Apr 2022 Location: The Lake District Posts: 200 ![]() ![]() ![]() |
Just a few! The bar is for work lights, I’ll take it off as a rack and ladder are going on. 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
The front is leaking worse than the rear so I’ll replace both and check the UJ’s too. 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
Gave it a little clean this evening.
![]() Click image to enlarge 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
That’s Superbulous!
And it’s got proper wheels too 👍 |
Thanks! I like the stance the wheels give it but combined with the suspension and 285 tyres, it’s a bit lumpy. I’ve already got a friend enquiring about them for his Range Rover Classic!
I fancy some sawtooths and Goodyear MTR or Duratracs for it 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
Yes I imagine they take some getting used to - but they are nice.
Sawtooth would look great 👍 |
Interested in recommendations for up to 7” led flood lamps for the bumper too. 2009 90 commercial.
Thank you for the info ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1025 ![]() ![]() ![]() |
Absolutely love a purposeful looking Defender
![]() More pictures please! 2008 2.4 110 Utility Station Wagon XS. |
This week, the 90 has been a commuting tool over the Lakeland fells and it’s done the job really well and quite economically for a Defner. The dry weather we had allowed me to clean up the rear crossmember.
Even managed to get a new mug to match it, no cup holders though ![]() ![]() Click image to enlarge ![]() Click image to enlarge 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
Since buying the 90, I’ve looked at the large aux driving lamps and thought they’re just too big for its face. Despite the rain, decided to remedy it with some smaller osram lamps that still kick out some light.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
The 90 was needed for a tip run today so on went the rack that I bought on holiday in Devon recently!
