![]() | Home > My Defender > Not my G4 |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1047 ![]() ![]() ![]() |
Absolutely perfect that is!
![]() ![]() 2008 2.4 110 Utility Station Wagon XS. |
Joncorry Member Since: 03 Apr 2022 Location: The Lake District Posts: 204 ![]() ![]() ![]() |
This evening, managed to steal an hour or two on the 90. Had a better attempt at tidying the crossmember with buzzweld chassis in one. Also cut off the old rotten mudflap brackets and fitted some m8 rivnuts to hold the new ones. Should have gone for new flaps too but I’ve a few MOT’s approaching so no unnecessary spending!
![]() Click image to enlarge 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
![]() Click image to enlarge Today’s tweak is very subtle… 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
It is very subtle and it looks so much better
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
To illuminate further on the subtle mod…
You certainly will see where your going when it's dark
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 788 ![]() ![]() ![]() |
What light bar is that? Looks great!
![]() The stealth mounting is very nice as well. ![]() |
It’s one from Osram, model is the VX1000-CBSM 41”.
The rack has mount points for individual spots as per the G4 vehicles but I made some small brackets to bring the bar forward a little. I’ll get a pic later of them. 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
Thought I best check the condition of the swivels as I recalled them being a bit mucky when I bought it.
Managed to clean them up a bit but the seals do need replacing along with one of the swivels. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Thankfully a job I’ve done before on the 110. 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
I started to tackle the extremely tired swivel seal… as soon as I took the weight off the wheel, grease poured out. The Caliper to carrier bolts were pretty seized so I had to strip from the swivel ball bolts and disassemble from the back. The ball is pretty pitted so will be replaced anyway but it’s taken a lot longer with snapped bolts in various components. Hopefully the near side will be easier!
![]() Click image to enlarge Loving the jack my niece bought me for my birthday, great bit of kit. 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
Yes those jacks are a great bit of kit
Managed to squeeze a few hours on the 90 recently. First job was to fit the new plates to the car after buying from a fellow forum member!
Then it was time to tackle the near side swivel, even just stripping it down is an achievement. The drive shaft and cv are in great shape and stamped GKN. The stub axle looks a bit worn/pitted so time to replace along with all the bearings. Just need to weather to get back on side. ![]() Click image to enlarge ![]() Click image to enlarge 2009 90 commercial. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
Enjoying seeing this progress. Keep the updates and pictures coming, please! 2017 L494 Range Rover Sport SVR
+ 1 ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
