Home > Puma (Tdci) > How to tell if an engine is mapped?
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
I have bought a 110 2.4 TDCI, and compared to my wife's 2.2 TDCI it has torque in spades. I can drive it around the country roads in 3rd or 4th, and it just pulls.
Do the 2.4's really that much more torque than the 2.2?
When I was changing the radiator, I see it has a JE Engineering Intercooler fitted, along with an ITG air filter. When I changed the oil pan, I saw someone had marked the conrod journal caps with 1,2,3,4 in red paint. Not sure if these marks are on a normal build.
The previous owner has no knowledge of it being mapped, as he never had it very long.
How can I tell if it's been mapped?
Thanks
John
Post #1066087 22nd Apr 2025 8:30pm
jst
Je use itg filters. Probably is mapped by them. Unusual bit not unheard of to have e an uprated intercooler on a std map. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1066091 22nd Apr 2025 9:17pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Given that performance, assume mapped and get a pyrometer fitted before you crack the head.
Post #1066103 23rd Apr 2025 1:39am
landy andy
As standard it won’t have writing on the engine components. Someone has been in there. Thumbs Up
Post #1066116 23rd Apr 2025 7:54am
revd
Write to JE (or ITG, Coventry, same parent) company and ask them - only downside with a positive result-you will then have to inform your insurance
Post #1066137 23rd Apr 2025 11:39am
John P
I’ve tried to track them down, and they appear to have closed down. 🙁
Post #1066139 23rd Apr 2025 12:09pm
andy63
I'm thinking that it might be possible to get an idea by looking at scan tool live data if the map has involved deleting functions like egr.. that will be obvious by looking at the demanded egr.. the figure won't change..
If the map hasn't involved deleting,
I'm again thinking that scope data may show up some features in the injection timing and rail pressure , but only by comparing with standard mapping traces..
Post #1066140 23rd Apr 2025 12:41pm
90 Dreamer
surely simplest is to get a power run at a local Dyno and you'll see if it makes reasonably more power instantly
Post #1066141 23rd Apr 2025 12:43pm
Minch90
My Ultra-gauge shows increased Hp and torque when the BAS map is active vs the base map. Never know how accurate the figures are but they make me happy 😂 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #1066142 23rd Apr 2025 12:55pm
Ianh
Member Revd makes a very good point. In the event of an accident etc your insurance would very likely be invalid if the vehicle has had a map but the insurance company has not been informed of such.
A minor accident may not cause an investigation, but a fatality, personal injury for expensive accident, even if not your fault, could.
Insurance companies will look for any reason not to pay out so won’t care that you say you did not know. In fact (unfortunately) this topic is evidence that you suspect you do have a map and could be used by your insurance company against you.
I don’t intend this to cause you stress, so please don’t shoot the messenger, however I think it does need pointing out so you are aware of the risks .
A good tuner, such as Bell Auto Services , will be capable of reading your ECU, advising if the existing Map is not standard and potentially the author of the Map. I would advocate you contact BAS or other similar respected tuner to see if they will perform this function for you.
Ps. Given you have an uprated intercooler and air Filter I would also advocate that you inform your insurance company of such as they are also classed as modifications. I would also look for other potential mods such as brakes etc that the insurance company needs to be made aware of.
Post #1066143 23rd Apr 2025 12:56pm
MK
I am on the same boat with a friend´s 2.4. He bought it used and he has no clue who did the job. I`va never driven a Defender like his. Absolutely awesome remap. I thought the remap was done by IRB but of course I never got a reply.
So the only way to check it is by plug in the ECU into a Kess machine or similar.
PS. However, the EGR was not disabled. Puma 110" SW
Post #1066147 23rd Apr 2025 1:47pm
lightning
As above
Call your insurance and tell them it's got a remap on it. You should be okay to report to them that it's an "engine chip 10-25%" which won't affect your premium at all with some companies.
Post #1066148 23rd Apr 2025 1:53pm
revd
https://www.itgairfilters.com
Same/similar company owners as JE
Ask if anyone remembers chipping your Puma
Post #1066151 23rd Apr 2025 2:08pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: How to tell if an engine is mapped?
Somebody told me, that cheap tuners just rise the injection pressure.
You can simply read that out.
Ypu've already found some mods that make it most probable.
What about thé EGR and CAT ?
Post #1066213 24th Apr 2025 12:53pm
Dinnu
On paper, the 2.4 and the 2.2 have same performance, but the poor little 2.2 need to squeeze harder to push its exhausts out.
Incidentally I type this from my bathroom, so I know what a 2.2 might feel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1066215 24th Apr 2025 1:32pm
