Home > Maintenance & Modifications > Frozen bits
ZeDefender
Frozen bits
Sigh - steep learning curve for me as winter sets in...
What's the best defence/solution for getting into my 110 when the handles and door rubbers (which were wet) are frozen solid. Missus nearly had kittens this morning (teachers can't be late Rolling Eyes )
Matt Tell someone you love them today because life is short.
Post #106558 13th Dec 2011 8:59am
Some people put silicon spray on the seals. QRZ 2e0vpf
Post #106567 13th Dec 2011 9:40am
Waldo
WD40 worked for me.
Spray on a rag and rub it all over the seals.
Stopped working after about 2/3 weeks so did it again. Defender 90 XS TD5 (03 Reg)
Post #106579 13th Dec 2011 10:32am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
WD40 will damage your seals in the long run so use silicone spray and lots of it. You can spray the locks and buttons too if you want, in fact you can spray silicone spray pretty much anywhere you like without damaging things. It's a good idea to carry a can with you in bad weather and give everything a quick spray if its really wet and then going to freeze. As a quick fix to get you in your can landy, warm water works but make sure you dry it all out after or you will have even bigger problems next time.
Pete.
Post #106584 13th Dec 2011 10:46am
Glynparry25
I think I was lucky when in UK/ Germany/ Austria as I never did any 'Freeze prevention' and never had any problems (could always get into the fuel cap too!).
I always use a high quality shampoo and then treat the door rubbers to a wipe down with autoglym interior shampoo..... maybe that is what stops it sticking?
Glyn Dog Sheep
Post #106587 13th Dec 2011 10:54am
ZeDefender
Many thanks all Thumbs Up
Guess I will go and buy some silicone spray (have to go buy some chilies anyway)
Now, about the window winders...
p.s. is "AutoGlyn" one of your own products Laughing Tell someone you love them today because life is short.
Post #106595 13th Dec 2011 11:54am
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
I found a smear of vasaline arouinf the rubbers and over the lock mechanism of the fuel cap works well... 2002 Defender 110 DC
Post #106620 13th Dec 2011 1:52pm
Zagato
I made the mistake of using hot water to thaw out my old TD5 door lock as it just froze up again at work in the middle of nowhere and I couldn't get back in again...I can't remember how I thawed it out again....probably peed on it Laughing
Post #106623 13th Dec 2011 1:58pm
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
Vaseline on the door seals, ACF50 on the locks & push button door handles. 2001 TD5 110 DCPU in Bonatti Grey
Post #106642 13th Dec 2011 2:45pm
BigMike
what he said.
Post #106646 13th Dec 2011 2:55pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Vaseline also reacts with rubber, better off with silicone spray.
A few years ago the parking brake froze up on my old TD5 90, made a hell of a bang when it freed up when I drove off.
Post #106651 13th Dec 2011 3:06pm
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Vaseline and rubber definitely don't mix.
People with wetsuit rub used to wonder why their suits were falling to bits - it was because they were using Vaseline. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #106655 13th Dec 2011 3:16pm
roel
Sliconspray and put a rubber hammer somwhere so if it still freezes you can tab it loose. Twisted Evil Roel
2003 90 Td5 (2009-now)
Post #106659 13th Dec 2011 3:21pm
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
With us seeing -19 in the UK fairly recently is it worth doing this, even over here? 2009 110 XS Station Wagon
Post #267220 16th Sep 2013 4:16pm
Instead of silicon spray you could use a tube of MS4 grease, which applies like Vaseline but is a rubber lubricant (also used on LR 2286cc crank seals). Good for sunroof seals too in my experience.
Post #267240 16th Sep 2013 5:36pm
