| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
Sunday a tip run, normal garden waste type stuff and all the old oil from previous oil changes.
Oil/water/screen wash checks 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1876
Investigated an increased rattle on the back door. Looks like the top hinge pin has gone, so parts on order this morning 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Wheel carrier bolts come loose maybe? 1999 Defender TD5 110
There’s definitely significant movement between the two halves of the top hinge when you lift the bottom of the door, and I’m going to whip the spare wheel off the door to ease the stress on it until it’s sorted, so I’ll double check the carrier whilst I’m at it.
Thanks for the suggestion 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Ahhh in that case, sounds like you have found the cause. 1999 Defender TD5 110
| Wookii Member Since: 05 Mar 2024 Location: Surrey Posts: 9
MOT day with these two causing mayhem. Pass with no advisories
Click image to enlarge |
| ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 383
How could it be otherwise... they are two beauties!!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
Going in for a couple of pre MOT jobs with IRB DEFENDER 90 TDCI XS,
| rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891
More towing..... This time a Range Rover Classic for recomissioning+++
| jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403
Click image to enlarge Added corner protectors. Dead simple. I preferred the smaller ones but they don’t cover the rips, so I installed these larger ones. 2002 td5 90 county hardtop |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21033
It’s a shame the rubber matting of that type (I have the same) isn’t more robust on the corners and edges.
Especially considering the high cost of them really, on the flat areas it’s good but gets weak on the corners and edges and sort of delaminates. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11094
Just be careful with the corner protectors as the top corner will mark your door card 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
| Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 256
Drove to Muirkirk and did the loop around Cairn Table.
Passed the monument to John Macadam Click image to enlarge Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
Fitted the new tailgate hinges
Turns out the top hinge was worse than a little play in it… Click image to enlarge Initially i did by a replacement pin kit which is listed as being suitable for late models but I can’t for the love of me figure out how you would have drifted out the old pins 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
| All times are GMT |
