Page 1382 of 1392 <123 ... 138113821383 ... 139013911392>
excossack
As part of the MSUK (Motorsport UK) requirements for having a MSUK call sign/radio, the radio needs to be certified every 5 years to make sure its still in spec etc.
For me, this means taking up carpets and removing wires so the radio can be sent off as my radio is remote mounted (the radio display is up front and the radio body under the rear seat)
Removal was OK. But during the refit I decided a tidy up of the wiring was needed. The wires ran along the side of the seat and cubby box and then under the carpets. The excess wires being bundled up by the side of the seat. With the carpets up time for a shake and a hoover of the rear under the seats etc.
Wires now run in split conduit to keep them the tidy
Both front seats removed and hoovered out underneath and removal of all those crumbs and other crud which get down the sides.
Removed the seat riser rails
Removed un-needed/unused/old power feed cables.
Re-assembled. Much tidier now. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1059243 2nd Feb 2025 10:12am
excossack
Sunday a tip run, normal garden waste type stuff and all the old oil from previous oil changes.
Oil/water/screen wash checks 1999 Defender TD5 110
Regards
John M0VAZ
Post #1059351 3rd Feb 2025 9:29am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Investigated an increased rattle on the back door. Looks like the top hinge pin has gone, so parts on order this morning 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1059389 3rd Feb 2025 3:31pm
excossack
Wheel carrier bolts come loose maybe? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1059392 3rd Feb 2025 3:59pm
Rosco
There’s definitely significant movement between the two halves of the top hinge when you lift the bottom of the door, and I’m going to whip the spare wheel off the door to ease the stress on it until it’s sorted, so I’ll double check the carrier whilst I’m at it.
Thanks for the suggestion 2007 - Stornoway Grey 90 XS SW - Gone
Post #1059412 3rd Feb 2025 7:30pm
excossack
Ahhh in that case, sounds like you have found the cause. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1059417 3rd Feb 2025 7:45pm
Wookii
 2013 Defender 110 Puma 2.2 USW Orkney Grey
MOT day with these two causing mayhem. Pass with no advisories Thumbs Up
Post #1059428 3rd Feb 2025 9:52pm
ruben
Spain
How could it be otherwise... they are two beauties!!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1059447 3rd Feb 2025 11:53pm
LR90XS2011
Going in for a couple of pre MOT jobs with IRB DEFENDER 90 TDCI XS,
Post #1059903 8th Feb 2025 8:37am
rustandoil
More towing..... This time a Range Rover Classic for recomissioning+++
Post #1060048 9th Feb 2025 5:52pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Added corner protectors. Dead simple.
I preferred the smaller ones but they don’t cover the rips, so I installed these larger ones. 2002 td5 90 county hardtop
Post #1060056 9th Feb 2025 6:49pm
It’s a shame the rubber matting of that type (I have the same) isn’t more robust on the corners and edges.
Especially considering the high cost of them really, on the flat areas it’s good but gets weak on the corners and edges and sort of delaminates. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1060078 9th Feb 2025 10:45pm
L110CDL
Just be careful with the corner protectors as the top corner will mark your door card Rolling Eyes Clayton.
Keeper.
Post #1060166 10th Feb 2025 9:50pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Drove to Muirkirk and did the loop around Cairn Table.
Passed the monument to John Macadam
 Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1060170 10th Feb 2025 10:10pm
Rosco
Fitted the new tailgate hinges
Turns out the top hinge was worse than a little play in it…
Initially i did by a replacement pin kit which is listed as being suitable for late models but I can’t for the love of me figure out how you would have drifted out the old pins 2007 - Stornoway Grey 90 XS SW - Gone
Post #1061106 22nd Feb 2025 3:36pm
