![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
Has anyone got theirs recalibrated to D300 yet using GAP? I’ve about every other thing activated and thinking that surely the remap must be possible too. But then again if it was then why has nobody sussed it out yet and posted online.
rabalam Member Since: 30 Jan 2025 Location: Washington Posts: 6 ![]() ![]() ![]() |
@northeye
Once you enable this feature for a soft touch, how do you activate it or configure your PIVI screen to show the softkeys? Thanks |
northeye Member Since: 18 Sep 2022 Location: Tokyo Posts: 19 ![]() ![]() |
Reboot the Pivi system with press and hold the off/volume button for 20 seconds.
DC-Defender Member Since: 23 May 2024 Location: USA Posts: 11 ![]() ![]() |
Anyone notice any additional options in the CCF file since installing the latest Pivi Pro 4.3.0 update?
@northeye
I have an interesting issue. I'm not sure this is why it's not working. The below is the module you posted in the original post. * MultiCAN-898 Rear Htd Screen Soft Button from "Not Fitted" to "Soft Button Fitted" The ACTUAL module on the GAPTool is: * MultiCAN-898 Read Htd Screen Soft Button from "Not Fitted" to "Soft Button Fitted" Could this be the issue? I cannot find the original "rear" module. I've up dated my Gaptool to the latest firmware. |
"read Htd Screen" is correct.
But it means "rear heated screen", I believe. |
@northeye,
Okay thanks, it must be my LR633 then, I've done the hard reset on the Pivi and still no soft buttons. I'll keep searching though. ~r |
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 128 ![]() ![]() |
These are the ones i changed. May depend on your model and year. Mine is a MY25
![]() Click image to enlarge ![]() Click image to enlarge MultiCAN-892 SideBar Climate Climate Icon on Side Bar Available - FICP Replacement MultiCAN-896 ReCircle Soft Button Soft Button Fitted with timed and latched logic MultiCAN-897 Max AC Soft Button Soft Button Fitted MultiCAN-897 Max Defrost Soft Button Soft Button Fitted MultiCAN-897 AC OnOff Soft Button Soft Button Fitted MultiCAN-897 Auto Climate Soft Button Front AUTO Climate Soft Button Fitted MultiCAN-898 Front Htd Screen Soft Button Soft Button Fitted MultiCAN-898 Read Htd Screen Soft Button Soft Button Fitted |
TC909 Member Since: 27 Jul 2021 Location: Lincolnshire Posts: 39 ![]() ![]() |
I've read the GAP IID G4 is setup to your VIN on first use.
What happens when you sell the car, can you set it up on a new vehicle then? |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 117 ![]() ![]() |
You can add a vehicle or transfer the tool.
https://www.gap-diagnostic.com/faq/ |
@colin68
I see you did not modify the; "* MultiCAN-882 Sidebar Controls from "Legacy" to "Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i"" Is this not required? thanks, ~r |
OVRLANDR Member Since: 16 May 2022 Location: New York Posts: 46 ![]() ![]() |
I had to make the change from “Legacy” to “Sidebar Controls with DSC + VC Drawer and VC Bar on 4x4i” on MultiCAN-882 in order for the sidebars to show.
I have a MY25. |
I have a MY25. |
norland Member Since: 09 Feb 2023 Location: uk Posts: 30 ![]() ![]() |
Can't say I see side bars cluttering up the screen as an improvement when the car has real physical controls...
