![]() | Home > Puma (Tdci) > My VCV Journey |
Joyosa Member Since: 13 Oct 2024 Location: Forcalquier Posts: 4 ![]() ![]() ![]() |
Thanks I will give that a try - did it once before and it showed a knackered injector.
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
Is the vcv valve on the 2.4 dismantable..
I've seen vids where a small clip in the base allows removal of the valve plunger this but on the one on my 2.2 I'm pretty sure it's a sealed unit.. I think I'd have to destroy it to get at the plunger |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2503 ![]() ![]() ![]() |
Indeed it is. A bush mechanic would polish it with 1000-2000 grit or turn the plunger inside. Puma 110" SW
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 245 ![]() ![]() |
Denso DCRS300260 Available at mymotorworld.com for £55 with free delivery as of course I need another one!
As it is warm this time I will do the re-learn, can I do this with my BAS remap installed or do I need to flash back to factory instead? Don’t normally bother but thought I would this time to create some novelty to the endless VCV journey. Thanks in advance Dicky 2.4TDCI 90 - everyday brilliance S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
