Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 98 of 111 <123 ... 979899 ... 109110111>
BadgerWaz
Does anyone know if all seats have the cooling fans/ventilation built in them from factory?
I've activated my settings but to no avail, and I must admit a ventilated man-purse is a welcome thing on a summers day Very Happy
Post #1040986 25th Jul 2024 8:09pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
No they are only fitted if you specified them on your original order. They are brilliant though Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1040998 25th Jul 2024 10:10pm
The_75th
pjeski wrote:
Might be worth trying:
MultiCAN-878 Corner Speed Adapt
Tried this one - no change that I could see.
Post #1041002 25th Jul 2024 10:53pm
takuyaf
Japan
Does anyone know the difference between 4.00 build 98 and 4.00 build 131?
Post #1041087 27th Jul 2024 6:02am
awktm
Australia
How did you access the beta versions?
Post #1041727 2nd Aug 2024 11:40pm
mohd
United Arab Emirates
TSR
Hello, does anyone know how to activate the traffic sign recognition?
i changed this to fitted but no luck
MultiCAN-742 Traffic Sign Recognition TSR
TSR Not Fitted
Post #1041764 3rd Aug 2024 2:36pm
emariu
Romania
Accurate speed readings
I wanted more accurate speed readings on board speedometer(mine was about gps read speed - 4km/h) with:
MultiCAN-838 from: Speedo market 0- 3.5% + 2kph
To Speedo market 1- 2.0% + 0kph
Now my speed is spot on with GPS readings.. BUT when I set my speed on ACC it only goes to the set speed minus 4 km/h
How to adjust also the ACC set speed to the correct value?
Thanks for helping
Post #1041797 3rd Aug 2024 10:41pm
Dannymm
You need to also adjust the following to match
MultiCAN-577 SpdoCalPercentScale
3.5% Scaling
MultiCAN-575 SpdoCalkmhOffset
+ 2.0 km/h
Post #1041809 4th Aug 2024 11:06am
emariu
Romania
Thank you!
Post #1041816 4th Aug 2024 12:23pm
emariu
Romania
3.5% Scaling
+ 2.0 km/h
Thanks!
Post #1041817 4th Aug 2024 12:23pm
The_75th
Any further thoughts on this? Is there possibly missing hardware?
Thanks Smile
Sheep
The_75th wrote:
Does anyone know if "Country Road Assist" can be enabled in the CCF?
As far as I can ascertain, the Defender has all the required equipment and the bulk of the logic looks to be actually built into the NAV, which is present as the same logic is used for the ECO Coach.
COUNTRY ROAD ASSIST
Country road assist is only operational when adaptive cruise control is active. See ADAPTIVE CRUISE CONTROL.
Country road assist is an enhanced feature of the adaptive cruise control system. Country road assist alters the vehicle’s speed for upcoming road curvature or changes to the legal speed limit on the road ahead.
Country road assist utilises information stored in the on-board navigation system and the forward-facing camera to determine the correct speed for the road ahead.
Country road assist utilises information stored in the on-board navigation system to determine the curvature of the road ahead.
Country road assist incorporates two features to reduce the requirement of driver interaction with the adaptive cruise control system. The country road assist features are:
Corner speed adaptation – the feature identifies and reduces the vehicle speed to a comfortable value if the current cruising speed is too high for an upcoming corner.
Speed limit adaption – the feature identifies the upcoming speed limit and updates the adaptive cruise control set speed.
Limitations:
The corner speed adaptation feature may not always be available or accurate, particularly in the following situations:
If the road's course is not clearly visible.
If the road is narrowing.
On wet, icy or snowy surfaces.
While towing a trailer.
When the accelerator pedal is pressed.
When the driver deviates from the set route.
If a navigation system other than the on-board navigation is used.
If the navigation system's map data is out of date, unavailable, or inaccurate. See MAP UPDATES.
The speed limit adaptation feature may not operate in the following situations:
In poor visibility due to:
Insufficient illumination of the road, or
Variable shade conditions, or
Rain, snow, fog and heavy spray.
In areas of light glare, for example from oncoming traffic, direct sunlight or reflections.
If the windscreen in front of the rear view mirror is dirty, misted up, damaged or obscured.
If the traffic signs are not detected due to dirt, snow or insufficient lighting, or otherwise obscured.
If the signs are ambiguous, for example in roadworks or signs in adjacent lanes.
During sharp turns when adjacent traffic signs are outside the camera's field of vision.
Varying maximum permissible speeds in individual lanes, for example at toll stations.
Post #1041837 4th Aug 2024 4:44pm
emariu
Romania
3.5% Scaling
+ 2.0 km/h
I tried several modifications to these settings, but I am getting a lot of errors (ABS,Emergency braking,DADC etc. ) which cannot be cleared.
Now my ACC doesn't even work..
Do you know what values are OK for not getting errors but still calibrate ACC speed setting?
Thanks
Post #1041952 5th Aug 2024 2:12pm
Dannymm
These are the values I used without any errors
3.5% Scaling was the default
Changed to 2%
+ 2.0 km/h was the default
Changed to + 0.0 km/h
Post #1041958 5th Aug 2024 2:26pm
emariu
Romania
Now it's working as it should
Thanks again !
Post #1041980 5th Aug 2024 4:33pm
RoysRover
United States
I saw in a previous post that boosting the cell signal was an option. Has anyone figured out how? Thank you!
Post #1042120 7th Aug 2024 2:03pm
