![]() | Home > Maintenance & Modifications > Nugget replacement air filter cartridge |
| Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 617
Thanks - I found it.
https://inlinefilters.co.uk/Filters-Air/Ca...N-FA14965/ Just ordered a couple. Thanks for the heads up |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341
This how mine came
Click image to enlarge 2007 110 TDCi Station Wagon XS |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2557
I purchased the NIPPARTS J1321017. Circa £18 delivered. Externally the main body of the filter is exactly the same diameter and length as the original Wesfill WA830 filter. It also has the same metal mesh on the outside and inside of the filter as the Wesfil WA830. The filter material is red, unlike the Wesfil, however it looks like a quality filter. For it to fit you do need to remove the thick rubber seal on the top ( it just peels off) and replace with some 10mm wide 4mm deep self adhesive ( one side) neoprene foam tape. It’s then a perfect fit. Edit - 2 weeks and several long high speed trips with engine under load and the filter has performed perfectly . No issues with vacuum gauge at all. |
| All times are GMT |
