Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 92 of 112 <123 ... 919293 ... 110111112>
emariu
Romania
thank you
Post #1037396 14th Jun 2024 8:02am
Helipilot
Anyone find an option to turn the annoying sound off when opening the door with the ignition on? I often get out of the car engine running and leave the door open.
Post #1037649 17th Jun 2024 2:56am
oboe
United States
US Spec LHD X Dynamic S Base Headlamp to LED Premium Upgrade
Posting these for anyone looking... these are the configuration changes that successfully enabled me to upgrade from base LED headlamps to Premium LEDs... following Simon's videos from PowerfulUK got the headlamps installed but the folks at IIDTool got me the CCF configurations to make it work! Thank you!
MultiCAN-471 MainBeamFdbkMech BCM detects faults directly (0x8)
MultiCAN-482 FntSdMkrDrvMech Driven via BCM (0x8)
MultiCAN-679 HeadlightsVariant Headlamp_Variant_Mid_C (0x6)
MultiCAN-750 High Beam Lights Not fitted (0x10)
MultiCAN-814 Laser High Beam Menu Independent Laser setting (0x4)
Unsure of this one;
MultiCAN-858 Fog Lamp Location Bumper Lamp Module (0x30)
Post #1037723 17th Jun 2024 11:09pm
Akmpro777
Can you disable this annoying thing for EU-based cars "Driver assistance resets to High" with Gap iiD?
If yes maybe someone can point me to where this is located. Basically want my Driver Assistance to remain at "Custom" after I restart the car.
Thanks!
Post #1038472 26th Jun 2024 2:37pm
Bobbobbobbob
Yes you can do it. I have to say I'm no expert on this but I changed it and it works for me.
MultiCAN-889 GSR2 EU Market Ft
GSR2 Country
Changed it to Non GSR2 Country
Obviously I don't know what the potential implications are.
Post #1038536 27th Jun 2024 9:23am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Great find Bobbobbobbob and thanks for sharing, I'll add it to the list Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1038537 27th Jun 2024 9:26am
Akmpro777
GSR2 Country
Thanks! Does it still show the "Driver assistance mode will reset to High upon vehicle restart" warning or this also completely disappeared?
Post #1038538 27th Jun 2024 9:38am
Bobbobbobbob
It still shows the message but remembers the last setting
Post #1038539 27th Jun 2024 9:58am
Akmpro777
Received my iiD tool today and can confirm the following:
1) Stop Driver assistance resets to High
Change it to Non GSR2 Country
Works perfectly. After restart stays at "Custom". No more annoying sounds.
2) Remember auto start/stop settings
MultiCAN-566 MHLastUserMode = Enabled
Doesn't work yet (d300 2024 model, eu specs). Will report in a few days, need to play around with resetting Pivi etc.
Post #1039250 6th Jul 2024 12:08am
Hairy Dan
Glad to hear the driver assistance one works Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1039251 6th Jul 2024 12:19am
lightning
What's "Driver Assistance" l don't see this message on my 2022 D250
ls it the collision avoidance and lane departure etc? I can access these in the menu but they always reset to "standard" when l next use the vehicle.
To be honest l would like the collision avoidance to remember l have turned it "off" as it's nearly caused an accident twice when lt activated unnecessarily.
Post #1039258 6th Jul 2024 8:33am
Hairy Dan
You don't see it on your MY2022 because it only started appearing on MY2024 onwards due to new legislation. Cheers Ian
Kielder 4x4 Safari
Post #1039261 6th Jul 2024 9:01am
lightning
Does anyone know if selecting the above with the GAP tool will also allow the vehicle to memorise the collision avoidance etc settings?
Post #1039269 6th Jul 2024 10:51am
Akmpro777
Update on the Start/Stop issue:
Not sure what exactly did the trick but it works perfectly now! So after I changed the MHLastUserMode = Enabled - the car was left alone for around 12 hours. After I started the car the Auto Start/Stop was on as usual. I turned it off, did 2 Pivi resets while the engine was running and after that pressed the seat memory button to remember the seat setting (m + 1 in my case).
Step by step:
1) Connect iiD
2) Disable start/stop
3) Change MultiCAN-566 MHLastUserMode = Enabled
4) Leave the car for 12 hours
5) Start the car
6) Disable start/stop
7) Reset Pivi
Cool Reset Pivi one more time
9) Press seat memory M + 1 (double check that the auto start/stop is disabled)
10) Turn off the engine. Open the driver's door. Close the car.
11) Start the car
And the car starts with start/stop disabled.
Hope this helps!
Post #1039270 6th Jul 2024 10:55am
sasa
Czech Republic
hello, did you manage a park assist?
i tryied
Park assist settings
Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears)
Needed 2 resets to PIVI for the app to appear in PIVI and a full car shut-down to clear the "Emergency Brake Assist Unavailable" error.
and checked also MultiCAN 658 still nothing. An icon does not appear on my screen.
Any trick? How long did you let you car locked?
thank you
Post #1039331 7th Jul 2024 9:54am
