![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 75 ![]() ![]() |
There are different multican/ Eucd settings for drl behaviors and settings. Like 10-20 different settings. Multican 458-through Multican 465 like 20 settings. You should experiment and get back to us!
2022 Defender Trek Competition 110 collectors edition! 2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
c4skp Member Since: 11 Oct 2020 Location: Dorset Posts: 24 ![]() ![]() |
It works on my 24 uk X. Thanks! Have enabled this as had to restore multiple times to factory after a lot of failed effort. Strangely the screen still says will revert to high when restart, but this doesn't, it stays on the selected setting. Has anyone got the SV logo on startup? |
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
I had the parking going as far as ‘start’ it would find spaces etc but start was greyed out. I changed two settings as per post above and it removed the parking steering wheel icon. I since changed it back to my previous setting and now the steering wheel icon is still missing and it doesn’t search for spaces etc. Any ideas?
Ratledge Member Since: 17 Jun 2023 Location: Murchison NC Posts: 28 ![]() ![]() ![]() |
I poked around a lot, but nothing looks important. Maybe EUCD-084 I think it was? |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 53 ![]() ![]() |
Hi I would like to activate TPMS. I know I need the module in the roof and sensors in each wheel.
Could somebody please check what settings they have? I think it will be Multican 101. There are many settings under 101, so I am not sure which one to select. Thanks |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1445 ![]() ![]() ![]() |
Mine is a UK car so this is the setting for EUCD-101
EUCD-101 Tyre Pressure Mode System TPMS With WBL, DLS & No HSPA & No WT (EU Legislation) ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thank you
I am trying to activate Tow Assist 2 on an L462. So the settings are slightly different. So far I have;
579 - Tow Assist 2 793 - ATCM rotary Switch fitted 795 - Selectable with Rotary All seems to work to the point that the start button is greyed out and the screen says " Raise the Terrain Response Control rotary." I raise it and nothing happens. Any suggestions? |
BD1 Member Since: 24 May 2020 Location: Chicago area Posts: 5 ![]() ![]() |
With walk away locking enabled is there a way to disable the horn from sounding if you walkway with the door open?
Rovering80 Member Since: 26 May 2024 Location: Bishop's Stortford Posts: 8 ![]() ![]() |
Hello.
New forum member here. I've been using the wealth of info on this thread with a G4 and have successfully activated some really useful features. So thank you in advance. I do have a question. I have been able to use the TR2 and ATPC features off-road which is brilliant as my car wasn't specced with them. If this had been activated as part of the original build would Dynamic mode be installed too on a P400e? It doesn't do a huge amount and I'm taking it in for a service soon so would like it to either be installed or not as it should be to avoid any potential warranty questions. Thanks Current: MY23 P400e HSE Dynamic |
As far as I know dynamic mode was only installed on the V8's from the factory, personally I haven't deactivated anything when my car was going in for any work and nothing has been said. But, as it's a 2 minute job to do it if you are worried just deactivate it and then re-activate it when you get your car back.
nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 108 ![]() ![]() |
Hello all...
I have a 2017 D5 that has been excellent. I how also have a d110 P400. Great vehicle, but I have noticed that on my D5 the rear lights are always on (even when the front side lights are on). This means that when I am towing a trailer, the side lights on the trailer are always on and that makes it easier to see the trailer in the mirrors. Is there a setting that will do this in the Defender? If it is the same as on the older D2 etc, it is related to the region settings on the car, but I don't know what setting it would be on the Defender. Thanks for any help you can give!! Nick |
That’s what I thought. Think I’ll deactivate before the service. As you say easily done. Thanks for replying and you input on the thread in general. Current: MY23 P400e HSE Dynamic |
ThunderBob Member Since: 23 May 2024 Location: Kentucky Posts: 20 ![]() ![]() |
I’m having the same issue. I can find spaces, select them but start is greyed out. Using Gap G4, latest firmware (build 90) on a 23.5 P300 North American Build Defender 90. Were you able to resolve the issue? Thanks |
