Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 88 of 112 <123 ... 878889 ... 110111112>
Mark1107
United States
Simon of our Powerfuluk trailblazers,
Has done a lot of videos on the matrix headlights. I would suggest that you check those out and contact him. He’s very responsive.
Now if we really want to add self parking fellas WE NEED TO DO MODULE COMPARISONS OF BCMS!
BCMs are where the magic happens! Jump on the bandwagon! We can crowd source this challenge!
Cheers,
Mark
(The only guy to get the oem locking differential added to a defender that didn’t have it!)
Plus I started this whole defender vehicle upgrades in the USA back in 2020. 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold)
2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair
2014 Range Rover L405 Autobiography Full Size Aintree Green
2014 Dodge Viper GTS Stryker Green
Post #1033914 5th May 2024 11:50pm
fst_drvr
Mark1107 wrote:
Start stop last user mode will not disable on the p400. Only p300 us specs.
If you want start stop to be disabled on p400, then you need a lead acid swap for your lithium battery or disconnect the plug black on negative terminal but you will lose heated steering wheel as well.
Only p300 gets last user mode stop start functionality.
I see... No wonder it didn't work on my car, I have a US spec 2022 p400, well guess I'll do it manually. BTW what do you mean by lithium battery? I'm pretty sure all defenders come with Bosch AGMs no?
Post #1033921 6th May 2024 6:33am
fst_drvr
Ian can you confirm MultiCAN-566 MHLastUserMode set to enabled does not work for p400 MHEV models? If so might be worth adding a footnote in the summary page to keep people informed, thanks!
Post #1033922 6th May 2024 6:46am
mmbanf
Italy
Cheers,
Mark
Thanks for the reply,
to help “dukluck”,I need to know US market premium headlight hardware.
For this reason I need the photograph of the headlight ecu scan.
I know very well the various differences in headlights on the European market, I have successfully retrofitted the matrix on my Defender, and helped other European users to succeed.
When, as in this case, a major failure problem arose, it was always due to an incorrect hardware problem.
I await support from the forum, possibly also in pm.
Marco
Post #1033923 6th May 2024 6:54am
pjeski
United States
It works fine on my p400 MHEV.
Post #1033929 6th May 2024 8:45am
carltb
 2015 Defender 110 Puma 2.4 DCPU Corris Grey
I can't even see the
MultiCAN-889 GSR2 EU Market Ft
using my G3. Even when showing unsupported.
2024 p400e 2025 Defender 130 V8
2025 Defender 90 D250 (wifes)
2024 Defender 110 p400e HSE (sold)
2015 Defender 110 Double cab
2004 Defender 90 Td5
Post #1033942 6th May 2024 11:49am
pjeski
United States
2024 p400e
Do you have the latest firmware?
Post #1033946 6th May 2024 12:43pm
carltb
Ah, that could be a factor. I'm on version 4.2.3 Build 176
Latest? 2025 Defender 130 V8
Post #1033950 6th May 2024 1:16pm
hthagood
United States
northeye wrote:
hthagood wrote:
Hairy Dan wrote:
These are the main changes from the G3, most of the MultiCAN numbers were there in the latest G3 firmware but they were all down as not supported, they now have options Thumbs Up
MultiCAN-882 Sidebar Controls
Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i
MultiCAN-892 SideBar Climate
Climate Icon on Side Bar Available - FICP Replacement
MultiCAN-894 Volume Soft Keys
Audio Volume Soft Keys pattern
MultiCAN-896 ReCircle Soft Button
Soft Button Fitted with timed and latched logic
MultiCAN-897 Max AC Soft Button
Soft Button Fitted
MultiCAN-897 Max Defrost Soft Button
Soft Button Fitted
MultiCAN-897 AC OnOff Soft Button
Soft Button Fitted
MultiCAN-897 Auto Climate Soft Button
Front AUTO Climate Soft Button Fitted
MultiCAN-898 Front Htd Screen Soft Button
Soft Button Fitted
MultiCAN-898 Read Htd Screen Soft Button
Soft Button Fitted
Anyone been able to get the soft volume control to function? All I get is a readout of “0” and no volume control. It will show mute status? Thanks!
I believe that the volume control key will work on only MY24 or above vehicles.
On my friend's MY24 worked, but mine MY23.5 didn't. Crying or Very sad
Disappointing.
Post #1033998 6th May 2024 8:52pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I don't know whether it works or not on the P400 but will add a note to let people know Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1034024 6th May 2024 11:29pm
pjeski
United States
Post #1034025 6th May 2024 11:31pm
Looneyfitter
Soft Button Fitted
Soft Button Fitted
Soft Button Fitted
Soft Button Fitted
Soft Button Fitted
Disappointing.
. I believe you need the larger screen for it to work
Post #1034031 7th May 2024 7:59am
hmgt3
Oman
Traffic sign recognition
Hi. I have a 22 V8. I think for our country traffic sign recognition is turned off. Does anyone know how to turn this feature on using the GAP tool?
Thanks in advance.
Post #1034147 8th May 2024 5:33am
Defendit..
Netherlands
I managed to change the alarm setting, Interior sensors.
Struggled 3 years now with it when my dog was in the car.
In the manual, 1st lock does not engage the interior sensors, for my country the first lock engages the interior sensors.
I needed to disengage the interior sensors always before in the Pivi menu with running engine.
So finally I can keep my dog shortly in the front with Windows partially opened whitout thinking before to change the settings
Multican 563. AlrmSensoronSingLock = Single Lock
Changed to - No Alarm Sensors on Single Lock.
( This setting could be region dependent, I know for the Netherlands and Germany at least) No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1034152 8th May 2024 8:30am
Ratledge
United States 2016 Defender 90 300 Tdi SW Auto Stornoway Grey
Just keeping up and for notes, the Parking Assist works up to the point when Start is greyed out.
The GSR2 setting does nothing for my MY23.5 D90S P300.
Has anyone figured out how to force headlights on, like required in Denmark?
Post #1034200 8th May 2024 5:17pm
