Home > Puma (Tdci) > Transit clutch and Output shaft change, couple of questions.
Page 3 of 4 <1234>
Waka56
Germany
Not too sure what you mean exactly. Might make sense while I'm in front of it haha Making my Defender great again. (Or trying to at least xD)
Post #1031761 16th Apr 2024 2:11pm
I did wonder if this from Amazon would work, essentially similar to the SP tool but less than a tenth of the cost.
https://www.amazon.co.uk/gp/product/B083FV...&psc=1
Post #1031765 16th Apr 2024 3:11pm
Zed
For £12 that’s well worth a punt. WARNING.
Post #1031770 16th Apr 2024 4:35pm
andy63
I think the poster is referring to the DIY method of removal of the spiggot bearing..
You can use the head of a bolt passed down to the back of the spiggot bearing cage and as long as its held tight behind the cage..
( Usually necessary to knock the back of the cage housing off) by inserting a spacer of some sort into the bore to prevent it moving you can then use the threaded section of the bolt along with a collar, nut, and washer to draw the bearing out of the flywheel... Have a look on the tube.. There are a number of vids on it I believe..
I ended up removing my spiggot by adapting a fitting for the slide hammer to sit behind the cage in a similar manner to the bolt head mentioned above..
That was after an attempt with a die grinder to destroy the cage.. Which I gave up on😩..
After the job was done I bought the set of pullers that black wolf has linked to as they seemed to be what would have done the job if I'd had them initially and they seemed a good price..
Stable door and bolting horse come to mind 🙈, but I have the tool now just in case and it looks adequate👍
Post #1031771 16th Apr 2024 4:35pm
Waka56
Germany
Ohh, makes sense now. I am definitely getting a "special" tool to do this. I won't be doing it at my home so I wanna avoid extra ways to delay things Laughing Making my Defender great again. (Or trying to at least xD)
Post #1031772 16th Apr 2024 5:02pm
Just be careful these things suddenly don’t snap, break or get jammed in somewhere or that can then cause more of a problem than you started with.
It can happen, especially if the base material might be chinesium. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1031775 16th Apr 2024 5:07pm
Waka56
Germany
Yup, defo a good point. What seals are usually getting changed for new when doing the clutch, the outputshaft and splitting the Gear box and the transfercase? The oil seal on the gearbox output is supposed to be changed? The transfer case output one?
I ordered already most of the parts, now checking the little things to be sure I have everything for Dday. Making my Defender great again. (Or trying to at least xD)
Post #1031781 16th Apr 2024 5:28pm
Dinnu
Many do the rear crank seal, and many of those many regret doing it. So suggest you read this before doing it, so you will not be another one of those many.
https://www.defender2.net/forum/topic78124.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1031814 17th Apr 2024 6:13am
Waka56
Germany
Thanks but I am not planning on removing the flywheel Thumbs Up Making my Defender great again. (Or trying to at least xD)
Post #1031817 17th Apr 2024 6:58am
Waka56
Germany
Pfff, been working on it today, it is taking quite a bit of time..
But at least I am not doing it for nothing.
I was doing good removing all the bolts on the bell housing, but then impossible to remove the gear box.. it's 8 bolts right? 6 on 1 side, 2 on the engine bay side? I wiggled the hell on of it, it moved like 1mm on the bottom part, but that's pretty much it. I'll look at it again tomorrow, any tricks?! Thanks guys, I'd love to be done with it tomo 🙃😉 Making my Defender great again. (Or trying to at least xD)
Post #1034126 7th May 2024 9:27pm
andy63
I thought it was 10 bolts securing the bell housing 🤔.. I'll check that tomorrow if you want.. As you say there are two from the engine side but there are a couple quite high up that are awkward to get at..and easier to access if you can tilt the back of the box down... That might be what's stopping the box dropping off..
I don't know whether you have, but I undo the intercooler hoses and the top hose from the radiator so the engine can pivot freely on its two mounts...
Post #1034131 7th May 2024 9:54pm
Waka56
Germany
That would make a lot of sense If I missed 2 bolts. I kind of hope it is that. Thx Making my Defender great again. (Or trying to at least xD)
Post #1034134 7th May 2024 10:29pm
Waka56
Germany
Well, here I was thinking the 2 top bolts were fairly accessible... I indeed only got 8 bolts... I glad I stopped not too late last night 😅
Post #1034153 8th May 2024 9:22am
andy63
Ahhh I see you are sorted.. And they are out👍
I had a quick look and whilst I can't actually see the whole way round the housing I'm fairly confident it is a 10 bolt job if memory serves me right..
Is yours a 2.2 with dpf..
If so did you have to remove the dpf to drop the box??
Post #1034159 8th May 2024 10:19am
Ianh
It looks like the front section of the exhaust is in the picture on the floor to the left of the blue trolley jack.
Post #1034182 8th May 2024 3:10pm
Page 3 of 4 <1234>
