![]() | Home > Technical > Clutch Flywheel Slave Cylinder --- advice needed |
DavidH Member Since: 22 Nov 2011 Location: Grenada Posts: 3 ![]() |
I have a 2007 110 double pickup no mods, I have had to replace two clutches in the last year. Less than 3,000 miles between replacements. The first replacement was due to a transmission defect which resulted in a warranty replacement of the transmission with a new clutch. This time the dealer gave me abill for £3,000.00 and told me the springs in the clutch had broken and damaged the flywheel. I've refused to pay the bill.
I replaced the clutch in my old Tdi90 once in 6 years. Are there issues with this models transmissions/clutches/flywheels. I've had defenders for 10 years and never seen anything like this. Any advice? |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
for a second clutch to go in 3000k mile something isn't right.
are you towing heavy loads or driving on very dusty roads as i know that r380 bellhousing used to let dust in. use the search facility on the website for clutch issues - i'm sure i've seen comments and woes before |
No towing has been done with this vehicle, no offroad. I had never seen anything like this before and am at a loss on how to deal with the dealer and/or landrover
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
I guess it is a Puma.
Are u sure the flywheel is damaged? It is a pretty solid piece of steel. What was the transmission fault? Maybe they fitted the old friction-cheese plate. Puma 110" SW ............................................................. Earth first. Other planets later |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Did they check the Gearbox Input shaft bearing for movement when they changed the clutch?
Brian. |
You mean radial or axial play? I understand the MT82 has noticeable radial play in the input shaft (also on Mustangs). Puma 110" SW
My thoughts exactly on the flywheel. I looked at the one they took out. There was some minor grooving and some some knicks where it looks like the springs did some damage. I would have thought that it could have been machined.
I have no idea as to what they did, but as it took them three and a half months to change the transmission last time I question whether they know what they are doing... how do you deal with a dealer who you have no confidence in, and is the only one around? |
