Home > Technical > Clutch Flywheel Slave Cylinder --- advice needed
DavidH
I have a 2007 110 double pickup no mods, I have had to replace two clutches in the last year. Less than 3,000 miles between replacements. The first replacement was due to a transmission defect which resulted in a warranty replacement of the transmission with a new clutch. This time the dealer gave me abill for £3,000.00 and told me the springs in the clutch had broken and damaged the flywheel. I've refused to pay the bill.
I replaced the clutch in my old Tdi90 once in 6 years. Are there issues with this models transmissions/clutches/flywheels. I've had defenders for 10 years and never seen anything like this.
Any advice?
Post #101785 22nd Nov 2011 11:24pm
farmer giles
for a second clutch to go in 3000k mile something isn't right.
are you towing heavy loads or driving on very dusty roads as i know that r380 bellhousing used to let dust in.
use the search facility on the website for clutch issues - i'm sure i've seen comments and woes before
Post #101973 23rd Nov 2011 4:53pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Towing should not bother it as i tow heavy everyday.... something is not right tho Question NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #102034 23rd Nov 2011 7:14pm
DavidH
No towing has been done with this vehicle, no offroad. I had never seen anything like this before and am at a loss on how to deal with the dealer and/or landrover
Post #102049 23rd Nov 2011 7:55pm
MK
I guess it is a Puma.
Are u sure the flywheel is damaged? It is a pretty solid piece of steel. What was the transmission fault?
Maybe they fitted the old friction-cheese plate. Puma 110" SW
Post #102774 27th Nov 2011 12:47pm
Lorryman100
Did they check the Gearbox Input shaft bearing for movement when they changed the clutch?
Brian.
Post #102810 27th Nov 2011 4:51pm
MK
You mean radial or axial play? I understand the MT82 has noticeable radial play in the input shaft (also on Mustangs). Puma 110" SW
Post #102813 27th Nov 2011 4:59pm
DavidH
My thoughts exactly on the flywheel. I looked at the one they took out. There was some minor grooving and some some knicks where it looks like the springs did some damage. I would have thought that it could have been machined.
I have no idea as to what they did, but as it took them three and a half months to change the transmission last time I question whether they know what they are doing... how do you deal with a dealer who you have no confidence in, and is the only one around?
Post #103079 28th Nov 2011 2:42pm
