|  | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
| Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448      | These are the main changes from the G3, most of the MultiCAN numbers were there in the latest G3 firmware but they were all down as not supported, they now have options    MultiCAN-882 Sidebar Controls Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i MultiCAN-892 SideBar Climate Climate Icon on Side Bar Available - FICP Replacement MultiCAN-894 Volume Soft Keys Audio Volume Soft Keys pattern MultiCAN-896 ReCircle Soft Button Soft Button Fitted with timed and latched logic MultiCAN-897 Max AC Soft Button Soft Button Fitted MultiCAN-897 Max Defrost Soft Button Soft Button Fitted MultiCAN-897 AC OnOff Soft Button Soft Button Fitted MultiCAN-897 Auto Climate Soft Button Front AUTO Climate Soft Button Fitted MultiCAN-898 Front Htd Screen Soft Button Soft Button Fitted MultiCAN-898 Read Htd Screen Soft Button Soft Button Fitted Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 | ||
|  29th Feb 2024 9:31pm |
| roccobarocco Member Since: 27 Jun 2023 Location: Ulm Posts: 15    | That's splendid news, can't wait any longer for my G4 arriving as soon as possible.    Again great support by GAP, they are doing a great job! Cheers Greg | ||
|  29th Feb 2024 9:48pm |
| Dammitdeano Member Since: 07 Nov 2023 Location: Brisbane Posts: 13    | I can’t follow which option I need to select from the G4 exchange web page to exchange my 3 month old G3 in Australia.  I’ve emailed support to figure it out. | ||
|  1st Mar 2024 10:15am |
| Santorini110v2 Member Since: 30 Jan 2024 Location: Southeast Posts: 5    |
 Just received my G4. Has anyone successfully activated Adaptive Cruise Control? If so, would you mind sharing the modules and selections? | ||
|  2nd Mar 2024 2:39am |
| matt4x4 Member Since: 18 Nov 2022 Location: North Posts: 16    |
 Hi folks.
 I got my exchanged G4 two days ago and was able to activate ACC on my MY23.5 D250 XS EUCD-023 Cruise Control Standard: Without cruise control Changed to: Adaptive Cruise Control Stop & Go MultiCAN-580 PTCruiseFitment Standard: Normal cruise fitted Changed to: ACC with Queue Assist fitted MultiCAN-809 ACC Stop Gap Setting Standard: Not fitted Change to: Fitted MultiCAN-712 ACC Lead Car Dist Disp Standard: Fitted Changed to: Fitted * this was already set on my car I also set these parameters, cause I read about it somewhere. But what does this really it do? MultiCAN-753 Adaptive Prog Mode Standard: Not fitted Changed to: Fitted And I found other settings, which are listed as unsupported, but sounded intresting to ACC. Perhaps some defaults to set in the PIVI – but did not find anything yet ?MultiCAN-712 MultiCAN-712 ACC Stop Gap Select ?Standard: Not supported ?Changed to: Fitted ?MultiCAN-712 ACC Accel Profile Select ?Standard: Not supported ?Changed to: Fitted In the "activation session" the tool was not able to clear 2 faults, which popped up with DADC. But after letting the car sit alone for lunchtime, I was able to clear the faults with the tool ACC now works fine .... Great work GAP-Team  | ||
|  2nd Mar 2024 9:38am |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3532    | l've had a reply from GAP
 The unit has to be sent back to them in Canada for the upgrade replacement scheme. l assume most people know this already but just in case anyone doesn't. Can anyone tell me the procedure to activate the "more accurate speedometer" using G4 tool as in the U.K. it's set to read 3-4 mph high. Using my G3 tool lf l just change it to +1 mph it doesn't change the cruise control so that still reads high. lf you change the other settings to reset the cruise control, the vehicle comes up with an error on the screen and defaults to 2wd with various safety systems inoperative | ||
|  2nd Mar 2024 10:11am |
| pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 118    | The procedure should be the same, and the G4 should reset the DADC. | ||
|  2nd Mar 2024 10:54am |
  ACC works like a charm. Thank you! What else is now available with the G4? Self park and ATPC2?
|  3rd Mar 2024 3:12am |
| DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 287    | All terrain progress control
 ***THROWS UP BRAKE ERROR WITH GAP iid3 TOOL but should work on iid4 tool as need to clear DADC which iid4 tool can do*** MultiCAN-476 ATPC Orignal: HDC Changed to : HDC and LSPC Possible lock up and 15 min wait required, no Pivi rese needed MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar | ||
|  3rd Mar 2024 6:12am |
| DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 287    | Possible park assist settings although not sure many people have made it works, possibly some people abroad but maybe not in the uk. Uk cars may be missing something hardware wise
 Activate Park Assist ***THROWS UP BRAKE ERROR WITH GAP IID 3 TOOL BIT MAY WORK WITH IID4 TOOL*** EUCD-059 Parking Assistance Standard: Without Parking Assistance Change to: PDC (Front, Rear) - Parking (Parallel, Exit) EUCD-099 Park Assist Camera Standard: Without Park Assist Camera Change to: With Park Assist Camera EUCD-140 Pdcautoactivationmenu Standard: Not supported Change to: With PDC Auto Activation menu MultiCAN-469 PDCAutoActivation Standard: Not Supported Change to: Default OFF configurable MultiCAN-500 PDCBtnFCIM Standard: Not supported Change to: Fitted MultiCAN-602 PDC Standard: PDC not fitted Change to: 10 Channel fitted ( Park Assist) MultiCAN-786 Park Assist Standard: Not Fitted Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears) MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar | ||
|  3rd Mar 2024 6:16am |
| Ratledge Member Since: 17 Jun 2023 Location: Murchison NC Posts: 28      |
 Supposedly, but apparently self-parking is not certain? Maybe just for UK, but "the jury is still out"... Mine came with ACC, maybe required? The one report above says they're likely missing hardware. We'll see shortly. My guess is that they dumbed down Defenders that are delivered in GB, maybe just "commercial" spec? | ||
|  4th Mar 2024 11:20am |
| nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 112    | Self Park doesn't work on my 2024 110.
 Same as other people have had... all menus seem to work, but parking won't start. Note: I am not in the UK. | ||
|  4th Mar 2024 11:52am |
| Ratledge Member Since: 17 Jun 2023 Location: Murchison NC Posts: 28      | Hmmm...  Didn't spec mine out: I'm a six months old D90S MY23.5 (P300). | ||
|  4th Mar 2024 11:58am |
| johnlad Member Since: 18 Dec 2023 Location: Blackpool Posts: 105    | How are you people sending your unit back. I’ve struggling to find a commodity code for the item and if you put gift and value of €5 as advised then you can’t insure it for it’s value.
 How are you guys doing it? | ||
|  4th Mar 2024 6:45pm |
| Posting Rules
