Page 1363 of 1393 <123 ... 136213631364 ... 139113921393>
Good luck from me too, be sure to check the lights etc, and tyres. Sure you will anyway!
Wink Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1026737 3rd Mar 2024 9:18pm
excossack
I've been chasing a squeak from one of the front pulley's on the Td5 110 . I replaced the belt tensioner pulley and that didn't cure the issue. But the noise sounded like it was the coming from the same area.
Fast forward two weeks to yesterday. While I was in the loft putting stuff away, I came across an old idler pulley. Took this to the shed and soaked the bearing in 3 in 1 oil while I looked at the focus.
Managed to get some Landy time and replaced the pulley. Noise gone Smile
The squeak was coming from the top idler pulley nearest the engine block.
New one needed. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1026758 4th Mar 2024 9:40am
Fatbaron
Fatbaron wrote:
After 3 years off the road for many a reason, it's time to get Big Red road-worthy again. Bought a new battery this week and she started immediately. Very Happy
She'll be going in for a MOT this week so fingers crossed. Today will be spent sorting a few electrical bits out and giving her a clean...
Well she failed (as expected) but only on the prop shaft, track rod end and position lamp not working.
All easily sorted by myself at home so I'm well happy! Not bad for being off the road for so long. Very Happy
Post #1027017 6th Mar 2024 4:54pm
Joncorry
 2003 Defender 110 Td5 G4 Challenge Tangiers Orange
I took mine for its MOT. All advisories addressed since last year along with a whole lot more and in the 1383 miles covered in 12 months, no more bad points were found - clean pass. 2009 90 commercial.
2003 110 G4 used in 03 and 06 events - its well travelled.
2002 Range Rover G4 Event car (Australian leg)
2008 Discovery 3 G4 UK Selections car
1968 Series 2a
Post #1027020 6th Mar 2024 6:01pm
Both good news. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1027040 6th Mar 2024 10:00pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
Finished putting undercoat on my spare roof for my pop top just a few days of worth of Top coat then I can mount the roof to the frame and get camping well hopefully soon enough 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1027060 7th Mar 2024 12:00am
L110CDL
Thumbs Up Thumbs Up Clayton.
Keeper.
Post #1027224 7th Mar 2024 9:47pm
Dinnu
Carried a load of bricks.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1027296 8th Mar 2024 4:13pm
excossack
Replaced and rewired the amber roof beacons on the landy. New wire and new connectors.
The idler pulley I fitted the other week appears to have failed. It was an old spare I had from a couple of years ago. But I do have a new one to replace it. Thats a job for next week. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1027456 10th Mar 2024 10:01am
excossack
I thought the replacement idler pulley would fix the squeak but no. I think its the other idler pully (nearest the washer bottle) - a new one on order.
Went looking for play in the steering. Found the steering box drop arm had some play in the arm on the splines from the steering box. Bent the locking tab washer out the way and re-torqued the nut.
Hopefully job done.
Then found some play in the steering damper bush at the fixed end. - new bush on order.
Oil/water/screen wash checked Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #1027631 11th Mar 2024 4:22pm
L110CDL
Not today but on Sunday ( yesterday ) i gave Millie a thorough wash at my local garage, it took 3 coins this time as she was well and truly muddy which she got on the Saturday after a great days green laning and on the Sunday i had to refit the N/S rear mud flap as it decided to come off from the body one end, i cable tied it up until i could do the fix, all done as if nothing had happened Very Happy Clayton.
Keeper.
Post #1027715 11th Mar 2024 10:20pm
excossack
Replaced the bushes in the steering damper - no more play. Smile
Also replaced (or so I thought I was going to do) the idler pulley that sits behind the radiator hoses.
I ordered a new one and this came with a new bolt and domed washer. All good.
Off with the belt and off with the pulley.
New pulley attached and tightened up. But....with the new pulley on it span freely and OK, but I found if wiggled the pulley I had play. Sad
Going back to the old bolt and washer, still the same.
Then I went back to the old pulley and old washer & bolt. No wiggle.
Faulty pulley ? Something I have missed? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1027978 13th Mar 2024 10:07pm
Dinnu
excossack wrote:
Replaced upper and lower shock rear absorber bushes with new ones as the MOT man advised they had play. Hopefully new ones will do the trick.
Just did the same, though only 1 side Whistle Once the damper was out, it was more obvious how much wear the top bush had. Hope the banging noise goes away. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1028058 14th Mar 2024 8:10pm
excossack
Seems OK so far. Fingers crossed. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1028094 15th Mar 2024 9:02am
Shock bushes seem to be going at a far more rapid rate, I guess a sign of how bad the roads have got.
I’m thinking of fitting pin to pin rear, I have the parts, haven’t got around to fitting it all. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1028151 15th Mar 2024 3:31pm
