Home > Maintenance & Modifications > Oil Filter Housing Cover.
K9F
There have been several threads relating to oil filter housing damage one assumes attributed to poor fitment or possibly impact damage.
http://www.defender2.net/forum/topic5004.h...p;start=15
http://www.defender2.net/forum/topic2470.html?highlight=housing
Following on from the stainless intercooler grille replacement that me and a fabricator from work came up with we got our heads together again and whilst nothing can be done to prevent brute force whilst fitting, there is something that can be done to prevent potential damage from impact. I am gauging interest to see if there would be any 'takers' that may be interested prior to a final costing and going into production. Price would be reflected in the numbers but would imagine it would be ballpark £45.....
The cover would be milled from aluminium having 6mm thickness at the base and 8mm on the sides. It could be anodized or powder coated but would bump the price up or 'au natural' dependant on opinion.
The cover is intended to be placed over the hexagon shaped boss at the base of the filter housing. It will be held in position by the sprung catches on the two opposing flats of the hexagonal boss and even the flange at the top of the filter would be covered.
Ear tiz.....Anyone interested? Whistle
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #102496 25th Nov 2011 7:29pm
BigMike
Bearing in mind its position, it would be pretty odd to get an impact on it, so on that basis, not sure why it needs a guard.
Post #102532 25th Nov 2011 9:28pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
If you could get your mate to make something like this for the Puma at the right price i would be interested ?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #102545 25th Nov 2011 10:25pm
K9F
Karlos,
That's 5mm galvanised steel and available for the princely sum of £150 on their website. Only a couple of hours work for you! Just shell out....you know you want to. Look good powdercoated....bling bling!
Can't possibly filch their design.....not the decent thing to do!!!! Whistle
Laughing Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #102567 26th Nov 2011 12:04am
fekete
Mal, it will not fit the Puma so you would not filch their design... i recon you would move quite a few ?
It was just a guideline on the product i was after ..as there isn't one made for the Puma Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #102582 26th Nov 2011 2:13am
K9F
Karlos, it is listed as available "Land Rover 90, 110 Puma 2007 on".....
http://www.extreme4x4.co.uk/acatalog/TRANSMISSION_GUARDS.html
With potential products a PDF drawing has quite often to be made which can take considerable time in itself if work has to be farmed out (like water cutting etc.) so a one off isn't cost effective. The fabricator I use is both talented and naturally a 'metal enthusiast' who takes great pride in what he does. He likes Land Rovers too. if you want something he will 'give it a go.' If indeed there is something that isn't available, is a good idea and there is a number of people who want one give me a shout, the more there are, the cheaper it will be!
The roof rack he made for his own vehicle is a sight to behold....It's a shed of a vehicle and the rack has been welded and bolted straight on....through the headlining as well! Maybe that is the equivalent of a builder's house looking like a building site?
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #102595 26th Nov 2011 9:45am
fekete
Fair play Mal, the one for the Puma isn't the same it do's not cover the complete bottom Big Cry
Thanks anyway Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #102605 26th Nov 2011 11:08am
markb110
Hi Fekete
I have a TD5 90 with the mid pipe replaced with a straight through pipe. Part of the issue why the full belly plate does not fit the TD5 or Puma is the silencer box.
I did not like the TD5 version so bought that version from Extreme, i did not use the rear bracket as it makes the rear of skid plate site lower.
I then bought some 150mm galv angle plates from screw fix and bolted to the chassis, i used a 10mm thick ali bar to make a new rear support.
This has been strong enough to jack on
If you would like some pictures please pm me your email address Karl.
Mark
Post #102607 26th Nov 2011 11:40am
fekete
Nice one Mark PM on its way Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #102630 26th Nov 2011 1:57pm
fekete
Sorry Mal, for hijacking your post ...you can have it back now Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #102632 26th Nov 2011 2:00pm
fekete
Re: Oil Filter Housing Cover.
Post #102633 26th Nov 2011 2:01pm
or fit one of these ...
protects the fuel cooler, the oil filter housing Thumbs Up
Post #102644 26th Nov 2011 3:02pm
leeds
The photo put up by by bp man is made by Entreq (site sponsor)
The photos put up by Fekete from the Extreme 4x4 are actually made by Safari Equip in West Yorkshire.
Both of them are available from your local friendly 4x4 overlander.com (site sponsor) Razz Whistle
Brendan
Post #102655 26th Nov 2011 4:35pm
T1G UP
Brendan
ooh did see that guard! whats the price please
Post #102657 26th Nov 2011 4:46pm
leeds
The Entreq ones are £157 or £159, details here plus a little bit for delivery
Brendan
Post #102658 26th Nov 2011 4:49pm
