![]() | Home > Maintenance & Modifications > Oil Filter Housing Cover. |
There have been several threads relating to oil filter housing damage one assumes attributed to poor fitment or possibly impact damage.
http://www.defender2.net/forum/topic5004.h...p;start=15 http://www.defender2.net/forum/topic2470.html?highlight=housing Following on from the stainless intercooler grille replacement that me and a fabricator from work came up with we got our heads together again and whilst nothing can be done to prevent brute force whilst fitting, there is something that can be done to prevent potential damage from impact. I am gauging interest to see if there would be any 'takers' that may be interested prior to a final costing and going into production. Price would be reflected in the numbers but would imagine it would be ballpark £45..... The cover would be milled from aluminium having 6mm thickness at the base and 8mm on the sides. It could be anodized or powder coated but would bump the price up or 'au natural' dependant on opinion. The cover is intended to be placed over the hexagon shaped boss at the base of the filter housing. It will be held in position by the sprung catches on the two opposing flats of the hexagonal boss and even the flange at the top of the filter would be covered. Ear tiz.....Anyone interested? ![]() ![]() Click image to enlarge ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
If you could get your mate to make something like this for the Puma at the right price i would be interested ?
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Karlos,
That's 5mm galvanised steel and available for the princely sum of £150 on their website. Only a couple of hours work for you! Just shell out....you know you want to. Look good powdercoated....bling bling! Can't possibly filch their design.....not the decent thing to do!!!! ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Mal, it will not fit the Puma so you would not filch their design... i recon you would move quite a few ?
It was just a guideline on the product i was after ..as there isn't one made for the Puma ![]() |
Karlos, it is listed as available "Land Rover 90, 110 Puma 2007 on"..... http://www.extreme4x4.co.uk/acatalog/TRANSMISSION_GUARDS.html With potential products a PDF drawing has quite often to be made which can take considerable time in itself if work has to be farmed out (like water cutting etc.) so a one off isn't cost effective. The fabricator I use is both talented and naturally a 'metal enthusiast' who takes great pride in what he does. He likes Land Rovers too. if you want something he will 'give it a go.' If indeed there is something that isn't available, is a good idea and there is a number of people who want one give me a shout, the more there are, the cheaper it will be! The roof rack he made for his own vehicle is a sight to behold....It's a shed of a vehicle and the rack has been welded and bolted straight on....through the headlining as well! Maybe that is the equivalent of a builder's house looking like a building site? ![]() Treat every day as if it is your last....one day you will be right!! |
Fair play Mal, the one for the Puma isn't the same it do's not cover the complete bottom
![]() Thanks anyway ![]() Last edited by fekete on 26th Nov 2011 7:36pm. Edited 2 times in total |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2701 ![]() ![]() ![]() |
Hi Fekete
I have a TD5 90 with the mid pipe replaced with a straight through pipe. Part of the issue why the full belly plate does not fit the TD5 or Puma is the silencer box. I did not like the TD5 version so bought that version from Extreme, i did not use the rear bracket as it makes the rear of skid plate site lower. I then bought some 150mm galv angle plates from screw fix and bolted to the chassis, i used a 10mm thick ali bar to make a new rear support. This has been strong enough to jack on If you would like some pictures please pm me your email address Karl. Mark |
Nice one Mark PM on its way
Sorry Mal, for hijacking your post ...you can have it back now
NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
or fit one of these ...
![]() Click image to enlarge protects the fuel cooler, the oil filter housing ![]() |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
The photo put up by by bp man is made by Entreq (site sponsor)
The photos put up by Fekete from the Extreme 4x4 are actually made by Safari Equip in West Yorkshire. Both of them are available from your local friendly 4x4 overlander.com (site sponsor) ![]() ![]() Brendan |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
ooh did see that guard! whats the price please |
The Entreq ones are £157 or £159, details here plus a little bit for delivery
Brendan |
