![]() | Home > Faults & Fixes (L663) > P0401 - EGR flow insufficient |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785 ![]() ![]() |
Is that one of these two?
Or perhaps this one, sensor circled in red and the tube in blue?
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 185 ![]() ![]() |
hi Retroanaconda, were you able to solve the problem? thanks for sharing.
Marco |
I’ll let you know at the weekend, picking the car up on Saturday evening.
Definitely not solved - problem now back as bad as before and P0401 fault also now showing along with the warning light again.
Back to the dealer we go ![]() |
91dm Member Since: 26 Feb 2024 Location: Ireland Posts: 39 ![]() ![]() |
I have this exact issue for the last four weeks.
Same P0401 code and hesitation/judder at 1200-1500rpm, worse on inclines. It's better driven in S keeping the revs up. Is it a cracked pipe / leak off somewhere? I think the EGR code is misleading LR? Mine is also going in for a new EGR. Good to know I'm not alone with this issue, first issue I've had. Thanks! |
The dealer replaced the exhaust manifold pressure sensor and its feed tube on Friday, and having done 300 miles home I am hopeful that it has been sorted. Fingers crossed it stays sorted.
great 90dv!!!, he found the problem straight away, however I'm glad you solved the problem. thanks for sharing.
Marco |
That's good to hear.
Mine is going in this Friday for a full EGR valve and cooler change for P0401 code. |
Retroanaconda, has your fault come back since?
New EGR assembly didn't make any difference to mine. |
No, not yet - seems good so far.
Thanks Retroanaconda, hopefully can get to the bottom of my issue.
A big thanks to Retroanaconda for starting this thread, saved me a lot of time! This was also the problem with mine, here's some pictures to help others:
Symptoms I had: >P0401 EGR insufficient code that would return every 50 miles or so after clearing codes >Hesitation / stutter at around 1200rpm which was more noticeable when the engine was under load, almost like someone switched the engine off for a second >Little mid range power, very flat acceleration Fix >Clean out the metal pipe from the exhaust manifold to the exhaust pressure sensor Here's some pictures: Code on diagnostic: ![]() Click image to enlarge Pipe is located behind this boost pipe. ![]() Click image to enlarge I also replaced the MAP sensor which seem to bring back the mid range power however the low rev issue was still present and P0401 code. ![]() Click image to enlarge MAP part number ![]() Click image to enlarge This is the pipe and sensor ![]() Click image to enlarge Access is quite tight so I managed to clean the pipe by feeding wire up from the manifold side. You can see the dry carbon coming out. ![]() Click image to enlarge Over 600 miles done since without any engine light. Hopefully that helps others. |
Excellent work - glad to see it can be done DIY easily enough. Suspect mine will need doing again in another 70k miles or so.
