Home > General & Technical (L663) > Key Fob Not Working |
Miran Member Since: 14 Feb 2022 Location: Portoroz, Slovenia Posts: 13 |
I have the same problem. Not regularly, every couple of weeks or something. Car is parked on same spot. No power lines in vicinity.
Changed the remote battery, it didn't help. Contacted the dealer - no definite answer or advice. Followed the advice from somewhere on the net and repeatedly locked and unlocked the car with remote. Same stuff. I (unwillingly) became used to it. Thank you ODPA, I' try also your advice. By the way: what is "KVM"? Miran L663 200 S 3,0 |
27th Sep 2023 5:40pm |
Lockley Member Since: 15 Feb 2023 Location: Herefordshire Posts: 16 |
Thanks ODPA. I had the same problem today. Thanks to your guidance I checked the fuses. They both looked okay, but I changed the five amp one anyway, and it all came back to life. However, when switching the old five amp back in again, it has remained working. It seems like removing and replacing the fuse is somehow resetting the KVM. Simply clearing the faults on the Gap tool did not do the trick. L663 D300 SE MY22. |
7th Dec 2023 7:36pm |
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 85 |
Glad my experience helped someone else. Interesting the fuse was fine. I had
Wondered if that was the case as you described but had not taken the time to test further. Great additional info. |
8th Dec 2023 7:32am |
