![]() | Home > Puma (Tdci) > Crunching Noise And Traction Control Light Flashes |
Another possibility is the diff-lock is stuck in engaged.
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
" ... And where exactly would the equivalent earth be on a tdci? ... "
I don't know to be honest, I don't have a wiring diagram for the ddci, I was just offering a possible cause and suggesting that sometimes, serious sounding faults can often have a simple cause and remedy. |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 ![]() ![]() ![]() |
Hello Simon, Eventually when yours went completely, and you lost drive what was the problem, and resolution ? Thanks |
AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 ![]() |
I had this a few times, same situation but very intermittent, over course of last few months. Intermediate shaft gave up a few days ago... if you've not had the shaft checked then I'd recommend doing so. |
M7even Member Since: 14 Sep 2020 Location: Dubai Posts: 23 ![]() ![]() ![]() |
Hello,
Reviving this old post but this morning I had the exact same problem, Whenever I'd pull away from second gear or first it happens, Took it to a LR specialist and he hooked up a OBD2 scanner and just to look at the live data from the speed sensors of all four wheels, 3 of them showed the same speed from pulling away except one which was stuck on 1, he just tapped the speed sensor a bit and it got fixed! Now when pulling away there isn't any noise and no flashes, hope this helps anyone who has the same problem. 2014 Defender LXV 2023 Defender 90 HSE |
nick.bw Member Since: 26 Oct 2020 Location: Essex Posts: 76 ![]() ![]() ![]() |
This is the best exact same issues I have.
Any idea on what the fix is? |
Mentioned it above, turned out to be a speed sensor on one of the wheels.
just tapped it and it got fixed. 2014 Defender LXV 2023 Defender 90 HSE |
Do you know where he speed sensor is located?
Thanks for the reply |
In the top swivel pin.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8365 ![]() ![]() ![]() |
Also check the sensor connections to loom. Cheers
Thanks all
Little spanner and tapped both sensors and no more traction control issues. It's bloody mucky down there. What's best to clean around the swivel pin? Cheers |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 799 ![]() ![]() ![]() |
Now that you have resolved it for the moment, it’s with checking to make sure the end of the front half shafts/cvs are shimmed correctly, if they are too sloppy you’ll find the issue will return.
Chris |
Cheers for the suggestion
