|  | Home > Puma (Tdci) > oil filter cover - transit fit? |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864      |
 Does anyone know if the plastic oil filter cover from a Transit is the same as the 2.4 Puma?
 Cheers Keith | ||
|  19th Nov 2023 6:07pm |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2556    | LR004508 looks to be the LR part number https://www.lrworkshop.com/diagrams/land-r...lter_44996
 See https://www.defender2.net/forum/post260254.html Last post, which states Ford part number is: 1303477. States same on last post of this topic as well https://www.defender2.net/forum/topic47861.html?highlight=1303477 Worth checking on somewhere like autodoc to confirm part numbers. | ||
|  19th Nov 2023 6:58pm |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864      | Thank you Ian,
 I had searched but couldn't find the answer, I've now ordered a pattern chinesium one from Amazon as a temporary fit 48 hour delivery and a decent OEM one for if it arrives in time or next oil change. Just waiting for the new radiator to hopefully conclude my recent coolant loss woes, its amazing I ordered new head etc from Frida at Turners on Tuesday, it was here on Thursday, also ordered a new Radiator, gasket sealant, antifreeze etc from France same day.............. Thanks again Keith | ||
|  19th Nov 2023 7:14pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058      | ^^ You don't happen to recall the part number for the later cooler housing, do you, either Ford or LR? | ||
|  20th Nov 2023 9:12am |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2556    | The canister version of the oil cooler is LR part numbers LR104386 LR058091 LR081697
 See https://www.lrworkshop.com/diagrams/land-r...er_2.2tdci part 1 Oil cooler - From DA - https://www.island-4x4.co.uk/engine-cooler...-7593.html There are a few cheap ford / LR equivalent ones on the net, but the their quality and fit would be a concern. | ||
|  20th Nov 2023 11:39am |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058      |  Thank you. | ||
|  20th Nov 2023 1:24pm |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2556    | There is a topic on here re fitting the new type, I think to a 2.2, and includes ford part numbers, but I can’t seem to find it | ||
|  20th Nov 2023 1:33pm |
| hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373  | Where do you guys see the advantages of the spin on filter? As i always do an oil analysis and a filter check, i am quite happy with the loose element. And the waste is also lower     | ||
|  20th Nov 2023 4:09pm |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2556    | one advantage is you can easy pre fill and fit the filter when you do an oil change. I do that with cartridge filters but it gets a bit messy with it overflowing. | ||
|  20th Nov 2023 4:42pm |
| Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 628    | Sorry I left this hanging.  I used a spurious part off eBay cost about £50 with gaskets. It arrived marked ford so was happy. The gasket however was hard and rubbish so I acquired a good one.  If I remember I had to use some longer bolts too. | ||
|  20th Nov 2023 7:28pm |
 I replaced mine as I knocked it replacing the engine. Should have left it off until I had it back in. I was being lazy. | ||
|  20th Nov 2023 7:31pm |
| Posting Rules
