Home > Puma (Tdci) > oil filter cover - transit fit?
ickle
Does anyone know if the plastic oil filter cover from a Transit is the same as the 2.4 Puma?
Cheers Keith
Post #1015674 19th Nov 2023 6:07pm
Ianh
LR004508 looks to be the LR part number https://www.lrworkshop.com/diagrams/land-r...lter_44996
See https://www.defender2.net/forum/post260254.html Last post, which states Ford part number is: 1303477.
States same on last post of this topic as well https://www.defender2.net/forum/topic47861.html?highlight=1303477
Worth checking on somewhere like autodoc to confirm part numbers.
Post #1015679 19th Nov 2023 6:58pm
ickle
Thank you Ian,
I had searched but couldn't find the answer, I've now ordered a pattern chinesium one from Amazon as a temporary fit 48 hour delivery and a decent OEM one for if it arrives in time or next oil change.
Just waiting for the new radiator to hopefully conclude my recent coolant loss woes, its amazing I ordered new head etc from Frida at Turners on Tuesday, it was here on Thursday, also ordered a new Radiator, gasket sealant, antifreeze etc from France same day..............
Thanks again
Keith
Post #1015683 19th Nov 2023 7:14pm
Siwynne
I changed the whole cooler housing so I could just have the spin on filters like the last defenders. It was dirt cheap and after many oil changes I was questioning the longevity of the plastic pot.
Post #1015702 20th Nov 2023 6:50am
^^ You don't happen to recall the part number for the later cooler housing, do you, either Ford or LR?
Post #1015716 20th Nov 2023 9:12am
Ianh
The canister version of the oil cooler is LR part numbers LR104386 LR058091 LR081697
See https://www.lrworkshop.com/diagrams/land-r...er_2.2tdci part 1 Oil cooler - From DA -
https://www.island-4x4.co.uk/engine-cooler...-7593.html
There are a few cheap ford / LR equivalent ones on the net, but the their quality and fit would be a concern.
Post #1015736 20th Nov 2023 11:39am
Thumbs Up Thank you.
Post #1015752 20th Nov 2023 1:24pm
Ianh
There is a topic on here re fitting the new type, I think to a 2.2, and includes ford part numbers, but I can’t seem to find it
Post #1015753 20th Nov 2023 1:33pm
hornet
Where do you guys see the advantages of the spin on filter? As i always do an oil analysis and a filter check, i am quite happy with the loose element. And the waste is also lower Rolling Eyes
Post #1015779 20th Nov 2023 4:09pm
Ianh
one advantage is you can easy pre fill and fit the filter when you do an oil change. I do that with cartridge filters but it gets a bit messy with it overflowing.
Post #1015791 20th Nov 2023 4:42pm
Siwynne
Sorry I left this hanging. I used a spurious part off eBay cost about £50 with gaskets. It arrived marked ford so was happy. The gasket however was hard and rubbish so I acquired a good one. If I remember I had to use some longer bolts too.
Post #1015810 20th Nov 2023 7:28pm
Siwynne
I replaced mine as I knocked it replacing the engine. Should have left it off until I had it back in. I was being lazy.
Post #1015812 20th Nov 2023 7:31pm
