blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18020 ![]() ![]() ![]() |
Yup, the letter size has to be correct, also on a modern vehicle the font has to be correct. It is an offense also to muck about with the backround or to put any kind of 'anti-Gatso' film on the plate (and the films don't work anyway). The old bill is also now far, far more likely to pull you it for number plate offences than ever before since so much traffic enforcememnt is done through ANPR, so I woudl have thought that the chance of getting stopped for that is very high. You might also want to consider that since technically the vehicle would not (or should not) pass an MOT with that plate, in legal terms it is unroadworthy which not only has insurance implications but also could conceivably enable the police to impound the car if it is on the road at the time (the fact that this hasn't happened for a number plate offence yet doesn't mean that it cannot happen). There is no reason why you can't put a standard plate on the grill above the winch, it doesn't seem to cause any overheating problems even in exceptionally hot conditions, and is at least legal. Above all, I have to wonder why you would want to change the standard plate for an illegal midget plate. Each to his own, I suppose! |
Bobble Member Since: 21 Aug 2011 Location: Hampshire Posts: 223 ![]() ![]() |
Tricky one that. An MOT Test is always underwritten with the clause that it shouldn't be regarded as a check of roadworthiness and certifies that the vehicle achieved a pass only on the day it was tested. Speculating as to if it would pass again is a bit grey and although "unlikely to pass an MOT" might highlight issues that could be grounds to issue an FNP, a car can't be classed as unroadworthy for something that would fail if it was tested. Agreed in the illegal bit though. I just don't geddit. ![]() |
chopdogs Member Since: 10 Mar 2010 Location: Wiltshire Posts: 108 ![]() ![]() ![]() |
[quote="Bobble"]
As per my previous post, they do not give points - just a fine. OK, it's a max of £1,000 but realistically that's not very likely. The chances of being stopped are relatively small - a fellow forum member had a similar plate on his 90 for several years and never got stopped, even in Stroud during the horse sales when the police are out in force. As for why, I want to do this.....it's purely aesthetic. I prefer the look of the smaller plate - I think that the full size plate is overpowering - wherever it is - next to the winch, on top of the winch or on the "flap". I guess it's a similar reason as to why people add flashy wing top vents. They may argue that it'll improve airflow and increase heating efficiency (or keep out the snow) - but deep down they just like the look. Or, similar to people who buy "oversize" tyres that protrude past the wheelarches. Technically that's illegal - so they are running the risk of being stopped and fined as well. It may have an effect on off road capability but underneath it's probably because they think their car looks nicer like that. So, having offended at least half of the forum, I'll get my coat........... |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
Chop - there are a few here that like to get on their high horses as often as possible (I got blasted for towing a car using a tow bar - apparently I should have used 2 inch thick steel chains and welded it directly to the chassis) but I guess the slightly more subtle approach is - why risk a fine for aesthetics? It DOES look better IMO but won't the possible chance of being stopped worry you a bit? Defender 110XS SW gone... now VW California 180 4 Motion.
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682 ![]() ![]() ![]() |
I'm a member of the non-offended element. Looks good - you know the consequences, and the aesthetics you want - your call at your risk! I think the fellow forum-ers are just trying to keep you out of trouble. Enjoy it if you like it, cringe when you pass a copper ![]() |
Fitting what you've admitted is an illegal plate "because it looks better".
Where's that thought process end then? I'm gonna fit a flame thrower, it'll look better that way, and Bodicea spikes on the wheels, they'd look cool.... Just accept it, the BiB frown on small plates for what is a fairly obvious but seldom-spoken reason. People with ickle plates don't want to make it easy for their vehicles to be tracked/ANPR'd, and people who don't want that are generally up to no good. Fair enough on the points thing though.....my mistake, drawing from experience some years ago of a Caterham driving mate of mine who found it was cheaper (to the tune of £60) to remove the front plate altogether and carry it in the boot, rather than fit an illegal one. "It just fell off officer" worked out far cheaper than "I know it's too small but it looks nicer". And saying other people fit big tyres and they're illegal so it must be ok, is utter lunacy. Every vehicle in the country has a VRN plate, so every copper knows the rules on them, as opposed to tyre packages which are a bit more unique.
Agree with this. ![]() ![]() I'll get my coat now too. Last edited by Bobble on 21st Nov 2011 1:31pm. Edited 1 time in total |
if you really really want small number plates and to remain legal there is a way ....
move to Switzerland ![]() |
You ever tried eating Toblerone without hurting yourself? |
I appreciate that some of you are trying to keep me out of trouble and I thank you for your concern
Yes - I guess I will be a bit nervous when I pass a copper - thankfully, where I live there don't seem to be many ![]() I'll see how I feel after a few weeks - if I am continually "looking over my shoulder", I can swap back to the full size plate - 10 minute job. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I never used to run a front plate at all !!!
Or this one..
![]() Even my Westfield...which even when I got 'roadblocked' by two Police cars, didn't notice ! ![]() |
i did in this though...I wonder why
I think the risk is more that some bored copper will use it as an excuse to pull you over and try and find something else. It is down to the risk you are willing to take at the end of the day - I know a few people who have run illegally spaced / sized plates for ages and got away with it, I also know a few who have been fined a number of times for it - including faint logos on the background.
When we bought our old TR 110 it had small plates with dodgy spacing - L11 OTR spaced to read L 110 TR. The previous owner had never had a problem with them but my OH got warned twice in a week by a local copper (luckily he didn't fine her) so we changed them. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Round here it's front fogs or other lighting issues. When the cops are looking at a row of cars, they seem to go for one which stands out (obviously). Prats driving with front fogs (in good visibility) are a perfect target to pull over...and have a good long look over the vehicle...and test the drivers attitude... A driver with a bad attitude at this point is certainly looking at further action ... and with front fog users...rightly so...string em up ![]() |
