![]() | Home > My Defender > What Did You Do In Your Defender Today |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Which model is it? |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
Hmm - bit of a list:
Heated windscreen fitted Steering guard fitted (from a forum member) Exmoor Trim tub cover fitted (VERY nice) New locking wheelnuts fitted (just as well - old "key" broke on last of the old nuts!) Replaced old steel spare with one of the 5 new boost alloys with Conti (brand new from a forum member) Still to do: Replace all door card clips & screws ACF-50 all internal doors Replace key fob batteries to see if this will actually make all the doors lock / unlock at once! 2001 TD5 110 DCPU in Bonatti Grey |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Got back from The Lakes.
Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Just got back from a weekend in wales
![]() Now got the 2 day clean ![]() |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
Didn't even turn a wheel. I took the IIA out instead. 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Me too, took 5 hours to get back ![]() |
Took us 3 hours + as well.... done some nice lanes there Tony good weekend ![]() Will post a few vids ![]() |
chopdogs Member Since: 10 Mar 2010 Location: Wiltshire Posts: 108 ![]() ![]() ![]() |
Old
![]() Click image to enlarge and new ![]() I had a backing plate fabricated with the same size holes so no need to redrill the bumper and it's simple to change back for the MOT, producer etc |
Bobble Member Since: 21 Aug 2011 Location: Hampshire Posts: 223 ![]() ![]() |
£60 and three points, right there.
Buzz Member Since: 11 Oct 2011 Location: Inverness Posts: 235 ![]() ![]() |
Why would you worry about number plate size on a Defender? As Bobble said, 3 points straight away now. I got caught on a motorbike I had just bought with a plate that was only slightly smaller than standard. I didn't realise. Missed the points but got a 60.00 fine and a lecture.
Here's the offical DVLA line:
"Offences It is an offence to alter, rearrange or misrepresent letters or numbers in order to form names or words or in such a way that makes it difficult to read the registration number. Characters must not be moved from one block to the other e.g. AB51 DVL must not be displayed as AB5 1DVL or AB 51DVL. Vehicles with illegally displayed number plates may FAIL the MoT test. The police can also issue fixed penalty fines for illegally displayed number plates. Offenders are liable to a MAXIMUM FINE of £1,000 and in some cases the mark may be withdrawn." So, as far as I can see, they cannot give you points but can give you a fine - usually £60.00 (it rose from £30.00 in 2009 |
As I've said before its only one less bottle of wine
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
The school run - I see a silver 08 plate 110XS SW every time I go and countless mum run X5s/X6s/etc. Defender 110XS SW gone... now VW California 180 4 Motion.
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
Do the letters not have to be a certain size too? Bikers seem to get pulled over a lot for having small number plates on the back. Could you not just stick the original on the bulkhead over the 'flap'? Seen that done a few times. |
