Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 63 of 111 <123 ... 626364 ... 109110111>
sullivan1337
United States
Nevermind Patrick is a wizard and literally replied in 5 minutes to my email.
Thank you!!
Post #1012758 26th Oct 2023 6:24pm
aajr
United States
atldef110 wrote:
Hi aajr,
Sorry for the confusion. I was not able to use it without errors. After activating the Park Assist, the feature works fine and it does what it supposed to do, however I get the famous error message "Emergency Brake Assist Not Available".
I hope that helps
Yes, very clear, thank you. Too bad, because it would be great to have, but not if it's going to give errors.
Post #1012802 27th Oct 2023 12:38am
Pauljm
Australia
G4R1 wrote:
I was wondering if anyone came across of activation of the Air Quality Sensor?
I believe it can be retrofitted also it looks like this is only available on 11.4-inch screen.
This is all mine has
* EUCD-150 Air Quality Sensor
With Air Quality Sensor
Post #1012929 28th Oct 2023 4:48am
Pauljm
Australia
Post #1012930 28th Oct 2023 4:48am
malibu
Australia
Mine also has EUCD-150 Air Quality Sensor
but does not have the screen. So i think there must be another CCF setting that turns on the screem.
Post #1012933 28th Oct 2023 7:07am
sullivan1337
United States
Adamalli wrote:
8. On demand center locking differential with the touch of a button.
@Adamalli or anyone else, what CCF edits does this require?
From what I can see this isn't a hardware change required?
Post #1013148 29th Oct 2023 11:11pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
This can be done with configurable TR, the following settings should sort it Thumbs Up
- Configurable TR
MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration
MultiCAN-755 Config TR Mode - Not available for selection > Change to Available for selection with timeout Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1013151 29th Oct 2023 11:51pm
sullivan1337
United States
Adding more info here!
To make the Configurable Terrain Response (Config TR mode) selectable from the rotary knob and not just the touch screen:
Along with the initial:
I was able to successfully select with the rotary after I changed the following:
MultiCAN-797 Ter CT Select In FCPB
- Changed to > "Rotary used for selection within touch screen"
Cheers! 24MY Defender 110 P400 X-Dynamic SE, Pangea Green.
Post #1013294 31st Oct 2023 4:56am
DefenderMidlands
If the gap tool can eventually read the DADC Driver Assistance Domain Controller and clear the DTC codes then I think the gap tool will be able to do activate ACC, ATPC , TR2 Auto, Park Assist, wheel size change etc. I believe Patrick at GAP is working on a solution to this MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1014056 6th Nov 2023 8:02am
DFNDER
Australia
Yes he is, I emailed him enquiring re the GAP tool for my MY23.5 and he said to hold off ordering until they sort that out.
Post #1014062 6th Nov 2023 9:15am
DefenderMidlands
These are the CCF file changes I made to make ATPC and Auto TR2 work, I also had to clear the DTC in the DADC driver Assistance Domain Controller which you cannot yet do with GAP tool but hopefully soon
EUCD-129 Terrain Response Fitment
‘With Terrain Response’ changed to ‘Auto Terrain Response/JDO, Dynamic’
MultiCAN-476 ATPC
‘HDC only’ changed to ‘HDC and LSPC’
MultiCAN-562 DynamicProgMode
‘Available for selection without timeout’ changed to ‘Available for selection with timeout’
MultiCAN-682 DynamicLiteMode
MultiCAN-696 ATCM Auto TR Mode Switch
‘Auto Terrain Response Mode selection switch not fitted’ changed to ‘Auto Terrain Response Mode selection switch fitted’
MultiCAN-754 Auto TR Prog Mode
‘Not fitted’ changed to ‘Fitted’
MultiCAN-778 ATPC Select In FCPB
‘Control interface not available in FCPB’ changed to ‘Available as shared purpose button’
MultiCAN-778 Ter Auto Select In FCPB
‘Control interface not available in FCPB’ changed to ‘Rotary used for selection within touch screen’
MultiCAN-789 Drive Mode Order
‘All Terain Vehicle Standard Order’ changed to ‘AlI Terrain Vehicle Including Auto Order’
MultiCAN-798 Ter CP Select In FCPB
MultiCAN-853 ATPC Button Type
‘Not fitted’ changed to ‘Hard Button Fitted’ MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1014067 6th Nov 2023 11:52am
BruceT
South Africa
Ive just had a look at my build sheet and it turns out I do have an air quality sensor fitted. Where do I find this screen please? I cant seem to find it.
Or does the display need to be "turned on"? If yes how do I do that please?
Thank you "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #1014072 6th Nov 2023 12:05pm
DefenderMidlands
Could possibly be this?
MultiCAN-510 AirIonizer
Front Air Ionizer fitted
With Air Quality Sensor MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1014088 6th Nov 2023 12:54pm
BruceT
South Africa
Thank you I will try that. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #1014097 6th Nov 2023 1:44pm
StromC
United States
Bringing this topic up again...
Has anyone had any luck on finding settings to disable the fog lights coming on with the indicator lights?
Post #1014236 7th Nov 2023 5:18pm
