Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 62 of 89 <123 ... 616263 ... 878889>
mmbanf
Italy
write me in pm
Post #1012180 23rd Oct 2023 7:06am
norland
malibu wrote:
are there any economic ways to access PathFinder for a few hours?
What is the story with the pathfinder laptops/tablets on ebay? How do they compare to Gap. Looks like they cost a little bit more, but if they really do offer full pathfinder operation, would surely be a better buy?
Post #1012254 23rd Oct 2023 2:53pm
Ratledge
United States 2016 Defender 90 300 Tdi SW Auto Stornoway Grey
As far as the speed limiter, I fail to see why anyone needs their Defender to go 143mph much less 170. Are we running from the popo? Rolling with laughter
Post #1012255 23rd Oct 2023 2:59pm
atldef110
United States
hcarranzacr wrote:
malibu wrote:
``mmbanf wrote:
atldef110 wrote:
I found a new feature today
- Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears)
Have anybody able to activate Adaptive Cruise Control yet? Can anyone with ACC send me their CCF?
hi, very interesting!! thanks for sharing. have you tried this and it works without errors? Thumbs Up
I tried the parking assist the weekend. It worked perfectly, as in, the car finds parking spots and parks itself. Amazing. Yes I also get the brake warning and 2wd warning. Interesting, when I reset all the settings and restarted the car, everything worked perfectly with no warning, and park assist, until the next restart and then park assist disappeared.
I suspect when GAP work out the ACC, all the other options, such as ATPC, TR2 and Park assist will all work at once.
Hi atldef110
I did you setup, but i didn't know how to activated o used to use parking assist mode?
When I change - MultiCAN-786 Park Assist
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears) - Collision alert is disable, any idea
Hi hcarranzacr
That didn't happen to me. When I made all the changes for park assist, I only got the "Emergency Break Error".
After activating the party assist with your GAP tool, you just need to slow down below 18 mph. Alternatively you can activate Park Assist via the Touchscreen. You also use the button to choose which mode you need, Parallel Park, Perpendicular Park or Parking Exit and to switch the system off.
Here you can find more information about it.
https://www.landrover.com/ownership/incont...tem%20off.
Post #1012257 23rd Oct 2023 3:04pm
aajr
United States
atldef110
I am a bit confused. Were you able to permanently clear the error message? In other words, have you been able to activate park assist and use it without any error codes? Your note seems to me to imply that you still have the error code, but I'm not sure.
Post #1012367 23rd Oct 2023 10:55pm
atldef110
United States
Hi aajr,
Sorry for the confusion. I was not able to use it without errors. After activating the Park Assist, the feature works fine and it does what it supposed to do, however I get the famous error message "Emergency Brake Assist Not Available".
I hope that helps
Post #1012369 23rd Oct 2023 11:16pm
G4R1
I was wondering if anyone came across of activation of the Air Quality Sensor?
I believe it can be retrofitted also it looks like this is only available on 11.4-inch screen.
 3.0L MHVE D200 S Pangea Green+Black Pack
Adv. + Off-Road and Family Packs
Post #1012426 24th Oct 2023 12:03pm
aquascape
I have this on the smaller screen
Post #1012429 24th Oct 2023 12:06pm
G4R1
Ohh, that's interesting. What is MY of your defender? Mine is MY 21 and I have a smaller screen and there is no Air Quality screen.
I'm trying to figure out if this can be activated as I already have cabin air ionisation with pm2.5 filter so I believe this menu screen can be activated.
Is the any chance you could share a photo of the Air Quality screen on a smaller screen? 3.0L MHVE D200 S Pangea Green+Black Pack
Post #1012431 24th Oct 2023 12:16pm
aquascape
Mine is MY23 and I had the family pack which added the 7 seats, 3 zone climate, air quality etc
Post #1012432 24th Oct 2023 12:18pm
G4R1
Thank you for the clarification! I have the family pack with 7 seats and 3 zone climate too. But air quality seems something new that is probably only available on newer vehicles. 3.0L MHVE D200 S Pangea Green+Black Pack
Post #1012433 24th Oct 2023 12:21pm
aquascape
Possibly could activate it with the GAP tool, this might be a start
• EUCD-150 Air Quality Sensor
With Air Quality Sensor MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1012438 24th Oct 2023 12:37pm
Pauljm
Australia
Speed accuracy
I set this to as I have 285x45r22 instead of 265x45r22 & the rolling diameter is bigger now 32.1
More accurate speed reading
MultiCAN-838 from: Speedo market 0- 3.5% + 2kph
To Speedo market 1- 2.0% + 0kph
When I set cruise control to 80 kph it does like 76 only. It gets worse the faster u go.
Anyone know why? It was teading low anyway?
Post #1012562 25th Oct 2023 11:52am
Pauljm
Australia
I've got that option & 8m pretty sure it's an extra filter under the steering wheel there is a youtude that shows how to change it. Guess you could see if the filter holder is there.
Post #1012566 25th Oct 2023 11:56am
sullivan1337
United States
adnan_u88 wrote:
I had the same issue for MY24 - CCF Version Not Yet supported. Once I changed to beta firmware (build 3509) it seemed to work okay.
Since then there has been a Pivi update, just tried to make some other ccf changes today and its failing to upload the ccf changes. May need to change the firmware again?
How were you able to get the beta build? I'm on build 3034 and getting this same error on my new MY24.
Post #1012755 26th Oct 2023 6:19pm
