Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 61 of 112 <123 ... 606162 ... 110111112>
brucehun
South Africa 2003 Defender 110 Td5 DCPU Java Black
All options now working.
Post #1011639 18th Oct 2023 8:37am
hcarranzacr
Costa Rica
malibu wrote:
``mmbanf wrote:
atldef110 wrote:
I found a new feature today
- Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears)
Have anybody able to activate Adaptive Cruise Control yet? Can anyone with ACC send me their CCF?
hi, very interesting!! thanks for sharing. have you tried this and it works without errors? Thumbs Up
I tried the parking assist the weekend. It worked perfectly, as in, the car finds parking spots and parks itself. Amazing. Yes I also get the brake warning and 2wd warning. Interesting, when I reset all the settings and restarted the car, everything worked perfectly with no warning, and park assist, until the next restart and then park assist disappeared.
I suspect when GAP work out the ACC, all the other options, such as ATPC, TR2 and Park assist will all work at once.
Hi atldef110
I did you setup, but i didn't know how to activated o used to use parking assist mode?
When I change - MultiCAN-786 Park Assist
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears) - Collision alert is disable, any idea
Post #1011730 19th Oct 2023 2:33am
brucehun
For me all that’s missing now is ATPC and TR2. Everything else I activated working perfectly. I enjoy the walk away locking and approach unlocking. Doesn’t work with the activity key though.
Post #1011733 19th Oct 2023 5:37am
hcarranzacr
Costa Rica
atldef110 wrote:
That’s exactly what happened to mine. Still with the brake error I was able to use it.
The feature park parallel or in a spot between two cars even if there is no car parked.
To activate the feature you should see a steering wheel on your Pivi above the camera, once you press that button, the car will start searching for an open parking spot while you drive around and it will show on your Pivi when a spot is found. Once it finds a spot, stop, press on the spot you want the car to park, press Start at the bottom of you Pivi and the car will start parking by itself. You won’t need to press gas or maneuver.
Hi I have same issue, did you found any solution o workaround
best regards
Post #1011736 19th Oct 2023 6:46am
hcarranzacr
Costa Rica
Hairy Dan wrote:
If you really want to change the engine power you can change the following
MultiCAN-580 GenericEngPwrOut
Market Limited Mid-Power Engine variant
MultiCAN-599 EnginePowerOutput
Engine Power Source - 200/430
Obviously change the setting to what you want, the above is from my standard car and obviously you do this at your own risk.
Does it work? Some say yes and some say no and I have been reliably informed that doing this can generate an error that your service department will be able to see when they plug it into Pathfinder, eg P167F (Non-OEM Calibration Detected) and P064F (Unauthorised Software/Calibration Detected). Some activation places are now offering a software remap so maybe they have worked out a way to bypass the Non-OEM Calibration/Unauthorised Software/Calibration errors but you would have to ask them that.
My P400 have this parameters from factory (3000 MHEV)
• MultiCAN-580 GenericEngPwrOut
Standard high power engine variant
• MultiCAN-599 EnginePowerOutput
Engine Power Source - 400/550
but is P400
Post #1011752 19th Oct 2023 9:04am
OHRT
United States
How did you get ACC to work? Or are you using it with the errors?
Post #1011872 19th Oct 2023 11:48pm
brucehun
@OHRT...My Def has ACC as standard.
Post #1011900 20th Oct 2023 12:40pm
DefenderMidlands
My D250 engine settings are
Standard mid power engine variant
Engine Power Source - 249/365
Post #1011912 20th Oct 2023 2:32pm
brucehun
Activity key won’t lock or unlock if approach and walk away lock/unlock are activated
Post #1011913 20th Oct 2023 2:37pm
hcarranzacr
Costa Rica
I found that if I change speed limit I get a error faumous error "Emergency break error" i change to 210 and 250 and in boot I get the same error, went set to default value the issue is solve
• MultiCAN-564 MaxVehicleSpeed
LIMIT_191_KPH
Post #1011941 20th Oct 2023 7:18pm
DefenderMidlands
What power settings does anyone have for a D300? Can anyone upload their ccf file from a d300?
Post #1011950 20th Oct 2023 7:52pm
roccobarocco
Germany
LIMIT_191_KPH
Yes, same here. I did the same modification, same error, still wanted to know if it works, went on the Autobahn, it works, however, fault remains. Tried on Disco5 D300.
Post #1011960 20th Oct 2023 8:58pm
malibu
Australia
I am looking at options to activate the following;
1. ATPC
2. TR 2 (Auto)
3. Parking assist
I am woundering if I use the GAP tool to configure the CCF and then find a mechanic with Pathfinder to relearn the DADC module. I know that GAP will sort this out, but I am not sure how long they will take and was keen to get these items working before Christams so I can enjoy the features.
Is this likely to work?
Post #1012173 23rd Oct 2023 6:12am
mmbanf
Italy
hi, atpc and tr2, it will work for sure, learn DADC central configuration, and restart gateway, automatic parking I don't think so, there are many shadows on the procedure, it may be necessary to reprogram some ecu.
Marco
Post #1012177 23rd Oct 2023 6:39am
malibu
Australia
are there any economic ways to access PathFinder for a few hours?
Post #1012178 23rd Oct 2023 6:53am
