![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
atldef110 Member Since: 01 Oct 2023 Location: Atlanta Posts: 11 ![]() ![]() |
Thank you Adamalli.
Adamalli Member Since: 23 May 2022 Location: Colorado Posts: 10 ![]() ![]() |
So I was way off on the module that needs to be reloaded/relearn the CCF. The module is DADC. As far as I can tell that module is not listed in the GAP tool. |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 185 ![]() ![]() |
hi, very interesting!! thanks for sharing. have you tried this and it works without errors? ![]() |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 282 ![]() ![]() |
Good find. I will give it a try tonight. Like mmbanf said, have you tried it and confirm
It works, one to add to the sticky of a few members confirm it works for them |
o-ren-ishii Member Since: 25 Jul 2023 Location: The Hague Posts: 43 ![]() ![]() |
Hey all,
Still looking for the feature to disable interior lighting, computer etc going on when opening the backdoor. Does anyone has an idea which eucd or multican this could be? Would be greatly appreciated! |
Ratledge Member Since: 17 Jun 2023 Location: Murchison NC Posts: 28 ![]() ![]() ![]() |
The result I get for Park Assist is "Emergency Brake Assist Not Available". I do see the "Auto" switch under Driver Assistance / Parking.
Something is not quite right, but even resetting all params doesn't clear that error. Also, telling the GAP tool to clear the error fails. UPDATE: ————— My cruise control and lane keep assist are not available and after driving a short distance I get the "two wheel drive" error. I reset everything yet again, and I will have to give it the 15 minutes to reset. Last edited by Ratledge on 2nd Oct 2023 5:04pm. Edited 1 time in total |
Hi there again,
@mmbanf, @aquascape and @Ratledge I have tested and it works pretty well. And I've tried both parallel parking as well as rear parking. Prior to enabling I already had the "Emergency Brake Assist Not Available" error from trying the ACC so I am not sure if enabling just the Park Assist would bring that error back or have anything related. No other error was found. I will say that the auto-parking is a little bit aggressive. It goes backwards pretty fast, so if you have a towing hitch on an extender like I do, keep an eye while the car does its work. It may go beyond what you would like to. To enable the feature you just need to press the command on your Piv and drive by the parking spot. Once the car finds the spot, it will ask if you want to start it. After that just sit and watch. Please let me know if it worked for any of you. I am curious to know if it works to other members without error. I will try and clear my "Emergency Brake Assist Not Available" and check it again. Here are some pictures of it working. BTW my Defender is a 2022 P400. ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
With the changes shown, I see the first toggle under Driver Assistance / Parking, but I don't see the second switch in Pivi.
Curiouser and curiouser said Alice... |
Good point @Ratledge.
It only shows when you drive. You have to be below 18 mph. It doesn't show when you are parked or above that speed. |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
I've just tried it but unfortunately I get the automatic braking error ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I also had the "Emergency Brake Assist Not Available" but after resetting everything and letting the car go to sleep the error was gone on a restart after 15 mins Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Sorry to hear that @Hairy Dan
Maybe try some variations of these two options. Both uses the LIDAR Breaking sensors. Until I clear my "Emergency Brake Assist Not Available" error, I will not be able to try without issues. EUCD-059 Parking Assistance Standard: Without Parking Assistance Change to: PDC (Front, Rear) - Parking (Parallel, Exit) Other options: - PDC (Rear) - PDC (Front, Rear) - PDC (360) - PDC (Front, Rear) - Parking (Parallel) MultiCAN-786 Park Assist Standard: Not Fitted Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears) Other options: - Semi-Auto VarB (Semi-automated park assist with automated steering) [/list][/list] |
coda0 Member Since: 07 Sep 2023 Location: Clearwater, Florida Posts: 5 ![]() ![]() |
If you change this, it will pop open your tailgate without turning everything on: - MultiCAN-770 Remote Release Tailgate Enabled This will make the rear door pop open when you press the button on the key fob |
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 49 ![]() ![]() |
I thought you needed to have soft close doors to make that feature work. Does this hold true for all versions?
