Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2265 |
Has anyone tried this and did it work.
MULTICAN 750 Cornering lamp disable UPDATE lt didn't work, they were already set to "disabled" in the menu but they still work so l assume the feature is locked. |
17th Sep 2023 4:30pm |
Ratledge Member Since: 17 Jun 2023 Location: Murchison NC Posts: 27 |
Guys, we need to find a volunteer with a P300 D130.
They are detuned 6 cylinder engines, and likely can be SW / CFF upgraded to 400hp. |
19th Sep 2023 2:53pm |
aquascape Member Since: 08 Mar 2023 Location: Sutton Coldfield Posts: 198 |
That's the same as for the D250 to D300 but nobody is sure whether it will work and/or through any errors. I know some companies are offering D250 software update to D300 again online
19th Sep 2023 2:56pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1335 |
If you really want to change the engine power you can change the following
MultiCAN-580 GenericEngPwrOut Market Limited Mid-Power Engine variant MultiCAN-599 EnginePowerOutput Engine Power Source - 200/430 Obviously change the setting to what you want, the above is from my standard car and obviously you do this at your own risk. Does it work? Some say yes and some say no and I have been reliably informed that doing this can generate an error that your service department will be able to see when they plug it into Pathfinder, eg P167F (Non-OEM Calibration Detected) and P064F (Unauthorised Software/Calibration Detected). Some activation places are now offering a software remap so maybe they have worked out a way to bypass the Non-OEM Calibration/Unauthorised Software/Calibration errors but you would have to ask them that. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
19th Sep 2023 3:14pm |
This is the same as changing a D250 to a D300
Someone braver than me, needs to change it and see if it works. l assume you'd be able to feel the difference if it worked. |
19th Sep 2023 5:38pm |
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 |
I'll throw in two cases of Bavarian beer and a pack of brats. Delivered world wide. |
19th Sep 2023 7:02pm |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 100 |
19th Sep 2023 9:58pm |
In that case I’ll deliver personally with my 110. Strasbourg is not that far
19th Sep 2023 10:12pm |
Defender_Virginia Member Since: 20 Sep 2023 Location: Virginia Posts: 10 |
In the CCF afs123 is probably Adaptive Frontlight System
20th Sep 2023 12:16am |
The Matrix headlamps are also classed as AFS123 Cheers Ian
20th Sep 2023 12:29am |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 34 |
Hi Team, I hope it is OK to ask a question about a Discovery on this amazing forum. My problem is I can't find any Discovery forum's that have made so much progress with the IIDTool as this one.
I am trying to configure Advanced Tow Assist. I have most of it working, but when I click start is asked my to lift the Terain response controller. The Discovery has a seperate controller, where the Defender shares a HVAC control. So my question is anybody on hear with a Discovery with Advanced Tow assist willing to share the CCF file or know the settings required to activate the Terain response controller. Again sorry to take the discussion away from the amazing Defenders. |
20th Sep 2023 1:23am |
I see Venture Automotive over in the North West are spamming all the Defender groups on Facebook with this
They will obviously be using Pathfinder to perform the upgrades Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
22nd Sep 2023 11:50am |
l wonder if it's just a case of changing the engine type in the CCF or whether there new software needed.
l did email LR Retrofits who used to offer this upgrade to ask them, but they never replied to my query. |
22nd Sep 2023 1:01pm |
Does anyone know if it's possible to activate the ATPC and if so, how it's done?
22nd Sep 2023 1:13pm |
