Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 51 of 111 <123 ... 505152 ... 109110111>
malibu
Australia
I know this is a defender forum, but you people are making amazing progress with the IIDtool. I have an IID tool and are using it on a L462 Discovery. Mine has electric 2nd and 3rd row seats, but doesn't have the intelligent fold screen on the Pivi Pro. Does anybody know which CCF settings I should change to make it appear? The only setting I can find so far is Multican 667, I have set this, but still nothing on the screen. I expect I need one more setting to get the menu on the screen. Thank you so much.
Post #1007169 11th Sep 2023 6:46am
lightning
[quote="lightning"]
Hairy Dan wrote:
Be warned if you change the engine power using the IID tool! If you do it the system records a permanent fault which will show up if you car is scanned by the dealers computer, it shows up as a power mismatch so your dealer will know that something has been done. JLR retrofits originally offered this change but stopped as it was being overwritten by dealers, they then started to re-offer it along with a software hack to prevent the dealer from seeing it, but it doesn't appear on their website anymore so maybe they have stopped again. Confused If anybody still wants to change it have a look at MultiCAN-580 Thumbs Up
So does it actually work, that is, do you get the extra 50bhp and extra torque?
Post #1007174 11th Sep 2023 8:06am
DefenderMidlands
Not sure anyone has tried it!
Post #1007175 11th Sep 2023 8:08am
Nicofender
Germany
Everyone waits for the one person having the guts to do it AND have it checked by LR to see if they can read it out 😄
Post #1007207 11th Sep 2023 12:34pm
lightning
"JLR retrofits originally offered this change but stopped as it was being overwritten by dealers"
This would indicate that it may work. l'm not being the first to try it though !!
Post #1007211 11th Sep 2023 12:45pm
Muehae
Germany
stevemfr wrote:
Thanks Ian! Thumbs Up
We do have all the bits and bobs and won't need extra power or engine trickery.
But; On the risk you guys have laborated on this in detail already, we would be interested in some read out Info of our d250 while driving:
Engine oil pressure
Engine oil temperature
Coolant temperature
Gear oil temperature
Voltage battery
Hydraulic pressure suspension
Compressor running yes/no
Using high beam and fog lights simultaneously
Possible?
Post #1007219 11th Sep 2023 1:36pm
malibu
Australia
Interesting when I change 476 to HDC and LSPC I received the Emergency brake error, when I changed 129 to Auto Terrain reponse from Terrain response I recieved the 2wd warning. So I think the 2 messages are not related. Has anybody worked out how to fix either of these error messages?
Post #1007312 12th Sep 2023 3:19am
Ratledge
United States 2016 Defender 90 300 Tdi SW Auto Stornoway Grey
Still no-go on forcing headlights on? It has to be possible, vehicles delivered in Denmark have to burn lights all the time.
I was able to find one that forces. AUTO lights mode, but. I believe it is the default here in the states, maybe? I believe the behavior changed, as in when I turn on the fog lights the Auto setting is no longer canceled.
Now I need to go find which setting I changed.
Post #1007313 12th Sep 2023 3:25am
mmbanf
Italy
HI,
I've been trying to solve TR cars for a long time,
the emergency brake warning never appears on my car, which instead appeared to Ian as a TR car setting error.
when I edit the hdc file to 476 hdc and lspc, only 2wd error appears, when I edit 129 Auto TR, only 2wd error appears.
Your cars probably have some different setting that leads to emergency brake failure.
Marco
Post #1007341 12th Sep 2023 9:34am
malibu
Australia
Interesting that you don’t get the brake error. i also noticed when I changed 129 I also loose LKA, Speed limiter, speed sign recognition and autonomously cc. So I am thinking it is around the image camera. Maybe it is not a setting, but a recalibration of the image camera. Would you be happy to send my your ccf file, I am keen to compare. I can send you a comparison file back.
Post #1007346 12th Sep 2023 10:12am
malibu
Australia
I am woundering what sensors Auto TR uses. It appears it detects wheel spin, so probably ABS sensors. Does it use the cameras to detect terain?
I notice some are using Auto Terrain Response, some are using Auto Terrain Response/JDO, Dynamic.
Is the error different depending on which attribute is used?
Post #1007442 13th Sep 2023 2:30am
lightning
QUOTE
more accurate speed reading
MultiCAN-838 from: Speedo market 0- 3.5% + 2kph
To Speedo market 1- 2.0% + 0kph
This does indeed make the speedometer more accurate.
According to my GPS it's now doing an actual 69mph at an indicated 70mph.
However it doesn't change the setting of the cruise control speed display.
So you set the cruise control at (say) 70mph and the speedometer is showing 67mph
So l think there may be another setting to change somewhere.
Post #1007708 15th Sep 2023 12:45pm
pjeski
United States
lightning wrote:
QUOTE
Mine is already set at To Speedo market 1- 2.0% + 0kph, do you want my CCF to compare?
Post #1007715 15th Sep 2023 2:21pm
lightning
Yes please if possible, if l can identify the changes l will post them on here.
l am guessing it's something to do with the cruise setup or calibration.
Post #1007716 15th Sep 2023 2:32pm
starbai
United States
Hey all just curious. Has anyone found a way to leave the DRLs on full brightness regardless of the settings of the headlights?
I like to run with just the fog lights (no head lights on) but when I do so it automatically dims the DRLs. I've been playing with the list but I've not had any luck yet.
Just throwing it out there if anyone was able to do it?
Note I already enabled no dim for the DRLs with the turn signals and hazards, and that has worked well.
Post #1007718 15th Sep 2023 2:54pm
