![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
aajr Member Since: 18 Dec 2022 Location: San Diego Posts: 44 ![]() ![]() |
Interesting. I looked at my settings and it shows disabled (and of course still shows the icon) on my car, so I was hoping enabling it would make it go away.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3245 ![]() ![]() |
l finally got to connect the GAP tool today with my Defender D250
Everything worked okay including registration. It connects with my ipad and reads all the various ECU's. The vehicle identification comes up and everything looks good. However when l try to select "vehicle config" the loading starts and then stops with "reading CCF wBackup" and then l get "operation failed E O" The other menu items seem to work okay. How can l proceed from here? l tried shutting down the vehicle and restarting. l got through all the loading procedures and then the same screen when l try to select "vehicle config" Have l missed a step somewhere? ![]() Click image to enlarge |
NoWayMe Member Since: 15 Jan 2023 Location: Canada Posts: 6 ![]() ![]() |
aquascape, mmbanf, MickD, Hairy Dan, thanks you guys all for the suggestions and support!! After going through everything again I finally got it working! You guys are the best!
![]() ![]() Click image to enlarge |
Great that yours is working.
Mine isn't !! |
What's you car battery voltage? Might try connecting it to a charger and letting it sit for a minute or drive it for a few miles and try again. All modern cars are super sensitive to low voltage. If that fails, I also suggest downloading the lastest harware version for the IID tool, assuming you haven't downloaded it within the last week. |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
Are you using the latest firmware on your device, there was a problem with a few people and Patrick updated the firmware so make sure you update. Failing that drop Patrick an email. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thank you for the heads up.
l managed to update the firmware last night so will try again today to connect it to the vehicle. l'll report back when l've done it. |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 157 ![]() ![]() |
lt may be worth posting a summary of things that can be changed and the file numbers, l was looking for the door open chime cancel and after searching fifteen pages of this thread l still haven't found it, although l know l read it somewhere.
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
+1. It would be good if we can have a location with all of the known & working options.
Every so often someone posts a summary but it quickly gets buried. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Resix Member Since: 20 Aug 2023 Location: Lisbon Posts: 2 ![]() ![]() |
![]() Click image to enlarge Hey everyone, thanks for all the inputs on here ! Got my IIDtool activated and have done this: MultiCAN-777 Ter Dyn Select In FCPB Standard: Control interface not available in FCPB Changed to: Rotary used for selection within touch screen EUCD - 245 Dynamic 1 set to “Dynamic 1 Content with Configurable Dynamic Mode Screen” MultiCAN - 562 DynamicProgMode. Set to “Available for Selection Without Timeout” MultiCAN - 605 ConfigDynamicMode. Set to “Fitted” MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout” MultiCAN - 777 Ter Dyn Select In FCPB. Set to “rotary used for selection within touch screen” EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode" Closed and locked car 4 times with more the 30 minutes and no Dynamic mode anywhere. 2023MY D300X Any ideias ? Should I reset the Pivi system ? Cheers |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 115 ![]() ![]() |
Yes. |
This has been asked before, but was never answered.
What happens if you change the engine from "D250" to "D300" in vehicle configuration? l assume the software is not present to actually upgrade performance, but you never know. lt is only software that determines the engine output. |
UPDATE
Downloaded the new firmware and all working now. Couple of questions though, for those more in the know. Where is the option to stop the door open "bong"? And can you switch off the seatbelt one as well? And why does it say currently "no cruise control" as it does have cruise. Does it mean no adaptive cruise control? Thanks ! |
