Home > Td5 > TD5 fuel pump rebuild with replacement VDO pump
dorsetsmith
Part needed
1 FP16700008 step less 1 ear clamp s/s 10.1 -11.8mm for green pipe at top pump ( Bearing Shop uk )
2 OR8x1.5-V75 O ring ID 8mm section 1.5mm Viton for low presser fitting lower part pump feed and retune from filter ( Bearing Shop uk )
1 VDO pump A2C59511614
Start by removing lower parts tank pump housing next removed and clean foot filter will need to be fitted to the new pump
you need to carefully remover the two low presser fitting lower part pump feed and retune from filter you can now remove and replace the two O ring
next remover old S/S clamp from green pipe at top pump with heat gun at low setting heat the green pipe and remover from the pump next remove +/- spade connectors
Your now ready to reassemble start with new S/S clamp over end green pipe insert pump high out let at the top pump in to the pipe Do-not crimp ear on s/s clamp till you have refitted both the lower white and black pipe to the pump badly next crimp up new S/S clamp and refit +/- spade connectors at the top the pump
Refit foot filter to the pump reassemble lower parts tank pump housing
Pump now ready to be used
Post #900257 27th Apr 2021 6:12pm
geobloke
Excellent. Thanks Dorsetsmith. Have pondered on doing this before. So that all comes to about £100 and probably a much better idea than buying a cheap OEM part Thumbs Up
Post #900260 27th Apr 2021 6:34pm
MalteseRover
Malta
hi,
in the process of stripping down the pump as I have come across many continental VDO motors on ebay for around £160 I am stuck at the green hose. I will continue tomorrow.
I cannot open the pictures but It is nice to know that it can actually be done Smile hope i do not snap something. Does the stainless steel clip require a special tool (name if possible)
joseph
Post #1006617 5th Sep 2023 9:51pm
NickMc
You can use side cutter or cv boot pliers if you’re careful.
These type will work https://www.amazon.co.uk/QWORK-Pliers-Clic...mp;sr=8-43
Post #1006624 5th Sep 2023 10:50pm
MalteseRover
Malta
Hello the clamp was removed the hose was still tight.
Is it ok to use a regular s/s clip instead of the ear clips?
Post #1006694 6th Sep 2023 3:19pm
NickMc
I’d use the ear clamps, they’re not hard to get, most motor factors would have them. No moving parts and tight seal.
Post #1006719 6th Sep 2023 5:46pm
