![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
I've got to ask, why do you want to disable your wireless charger? Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 86 ![]() ![]() |
Thanks Nicofender just doing my part. 👍
As for the wireless pad charger it is too bad that LR did not just put an on off switch for it on the dash. My Toyota truck has this making turning it off easy. You could use the little plastic cover from LR as an option. Here is a picture of the owners manual about the charger which points out some good reasons to turn it off or use the cover. ![]() Click image to enlarge |
MickD Member Since: 28 Jul 2023 Location: New England Posts: 28 ![]() ![]() |
I got my activity key today and was able to code it using the IID tool without issue. My car is a 2023.5 and came with 2 keys, so it seems like it would have the updated KVM. However I do have the analog gauges, so perhaps they skimped on the KVM as well. One thing to note is the vehicle has to be in service mode, which you can enable from the Land Rover phone app. |
After using it for a few minutes I noticed some odd behavior
- Approach unlock / lock doesn't work - I can unlock the car using the button on the door handle, but I cant lock it that way Anyone know if that's expected? I could understand approach unlock/lock not functioning as it seems the band is very conservative with power so it may not be broadcasting all the time. But it's strange that the lock button does not work. The rear hatch functions normally. |
That's brilliant, glad you tried it and it worked ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
This is what happens on my MY2022 so I gave up with it, by the way do you have the approach lock/unlock switched on in your Pivi settings? Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I do have approach unlock and lock enabled, and it does work with the key fobs but not the activity key.
Does yours work with your activity key? |
I think I have it working also but can't be certain as I haven't got access to a trailer at the moment, I thought I may have been able to trick the system with a trailer board plugged in ![]() ![]() One thing that you mentioned was not getting it to show up straight away, if you are doing an activation that involves adding something to the Pivi screen you can always reboot Pivi after the car has gone to sleep but you can also run a programme on the IID tool. I do this after most activations now and can get things to show up straight after. ![]() Menu>Service Test>IDMA>Allow Central Configuration Data Learning ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Apologies I didn't read that properly, I thought you meant just approach lock/unlock in general wasn't working not with your activity key. Unfortunately I don't have an activity key to test. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 279 ![]() ![]() |
Mick d. out of interest with your gap tool does it say your kvm is locked for life?
I didn't notice. I can check. Where would I look for that info?
It’s in the RFA remote function actuator section under ECU settings (or something like that, I haven’t got mine connect to check exact wording) and then it’s the KVM state you need to look at.
It will be interesting to see if your says locked forever and you have managed to program an activity key to it. ![]() Click image to enlarge |
It says NOT Locked Forever. I guess I got lucky with the supply chain issues in this case. A small win after not getting the digital dash or 11" screen
