Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 42 of 112 <123 ... 414243 ... 110111112>
ODPA
United States
Advanced Tow Assist is Working!
After some trial and error and comparing my 110 without Advanced Tow Assist to my wife’s 130 with it I have been able to get this to work. Tested it out again this morning. At this point I am thinking it is a matter of letting it sit in the system for a while and after several sleeps and starts along with a few PIVI reboots it finally took. Here is a list of the changes and then I would suggest being patient as it might not activate immediately.
MultiCAN-579 Tow Assist
Set to Tow Assist 2
MultiCAN-635 Towing
Set to Not Support if not already set to this setting.
MultiCAN-696 ATCM TA2 Switch
Set to Tow Assist 2 feature selection switch not fitted, again if not already set to this.
MultiCAN-793 TA2 Input Control
Set to HVAC rotary.
MultiCAN-795 TA2 Select in FCPB
Set to Rotary used for selection within touch screen.
Post #1004388 16th Aug 2023 6:35pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Great work Scott Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1004443 16th Aug 2023 11:36pm
DefenderMidlands
is there any disadvantage to enabling this in case I was to use it in the future? I have a tow bar for my bike carrier and may occasionally tow a trailer.
Post #1004468 17th Aug 2023 10:32am
Hairy Dan
There is no real disadvantage in enabling it as it will just sit there and wait to be switched on, it won't interfere with anything by being enabled Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1004469 17th Aug 2023 10:37am
MickD
United States
That's fantastic, thanks for working it out. I'm looking forward to trying it out.
Looks like I was missing "MultiCAN-793 TA2 Input Control"
Post #1004478 17th Aug 2023 11:38am
ODPA
United States
I would agree with Ian that there is no disadvantage. You also do not have to use it with a trailer either just because it is added to your vehicle. There are steps you have to take to use it and if you don’t it is just like it isn’t there. Have fun.
Scott
Post #1004484 17th Aug 2023 1:14pm
Brockmoor Howard
Belgium
Hi Patrick.
I was trying to add a new key with the tool. It was not working.You informed me later that the KVM was definitely blocked and therefore had to be changed with a new one.
However I found an established car key company that was able to program the key without KVM change.
Price €200 for the key + €150 for the programming.
I wonder how they did that?
Post #1004489 17th Aug 2023 2:30pm
DefenderMidlands
Would be good to know. I would like to buy an activity key but my kvm is locked for life so not sure if I can
Post #1004491 17th Aug 2023 2:39pm
Brockmoor Howard
Belgium
I wanted to transfer the activity key of my previous L663 to my new.
Impossible without a specific KVM + new activity key. Total cost for retro fitting key+kvm + work/progr € 1.047 incl 21%VAT
Crazy for something you can miss most of the time, unless you want to go scuba diving with your key fob.
Post #1004492 17th Aug 2023 2:53pm
DefenderMidlands
I found that I can use my waterproof Apple Watch and leave the key and my phone locked in the car.
No idea but is a workaround
Post #1004493 17th Aug 2023 2:54pm
MickD
United States
What is KVM?
Based on YouTube videos I've seen I thought you could add an activity key using the GapIID tool. Is that not the case?
Post #1004498 17th Aug 2023 4:22pm
Hairy Dan
The KVM is the keyless vehicle module. Land Rover started locking down the KVM to prevent people breaking into cars and using a tool to code a new key to the car and then steal it. But it seems that not all KVM's are locked down eg if you car was only supplied with one key the KVM was left unlocked so that the dealer could add your second key when it arrived. Some of the earlier cars are also unlocked for whatever reasons so that may be one of the videos that you watched. If your KVM is locked that means the IID tool can't add a another key and the dealers Pathfinder system is unable to also, you have to replace the KVM to replace keys. Now I notice above that Brockmoor Howard has had a key added by using an established car key company but I don't know how this company bypassed the 'locked' KVM Confused Cheers Ian
Kielder 4x4 Safari
Post #1004503 17th Aug 2023 4:41pm
MickD
United States
Thanks for the helpful explanation.
I just ordered an activity key a few days ago as I thought it was going to be a simple add. Fortunately I got it for a very good price in case I have to pass it on.
Post #1004512 17th Aug 2023 6:10pm
Nicofender
Germany
Hero of the day ODPA! Bow down
Post #1004582 18th Aug 2023 10:31am
holtenc
United States
Probably superfluous information for most people, nevertheless extra information never hurts: I wanted to disable my wireless charging pad. Changing MultiCAN-767 Wireless Device Charger to Not Supported OR Not Fitted (I tried both) only disabled the status icon from appearing on the infotainment center screen. The hardware is still functional and still charges your phone. Rolling Eyes
Post #1004618 18th Aug 2023 2:45pm
