Home > Maintenance & Modifications > Clear Indicator lenses |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
I've used these:-
http://tinyurl.com/66o9lph Last edited by WelshGas on 19th Mar 2011 7:58pm. Edited 2 times in total |
19th Mar 2011 7:53pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
link don't work
found the lights are they bright and do you need to get the resister with them ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
19th Mar 2011 7:54pm |
I haven't got the resistor. There is no bulb warning system for the side/tail/braking lights on the Defender to my knowledge so no need for the resistor.
They are brights. There are other bulbs on ebay with upto 25 LED's per cluster. |
19th Mar 2011 8:02pm |
Cheers mate the reason i asked is i got some from ebay and they was ... NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
19th Mar 2011 8:27pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
I put led clusters in them that I got off eBay. Youre right, if you put those conventional bulbs you can get which have been painted red, they make the light look a bit pink. I didn't like them either so went for led's. Pete |
20th Mar 2011 10:09am |
Pete are they the leds in your link you put in the stop and tail ?
these http://cgi.ebay.co.uk/1x-RED-13-LED-BA15S-...519805d0a2 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
20th Mar 2011 11:23am |
No the led in that link was for the fog lamp. The stop tail ones I bought are here:
http://cgi.ebay.co.uk/Land-Rover-Land-rove...3727wt_922 |
20th Mar 2011 11:47am |
Cheers Pete, Ordered NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
20th Mar 2011 12:01pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Where's the best place to get the clear lenses from? Do you have to buy replacement units, or can you just change the lens? I read somewhere that the lenses on later vehicles are sealed to the lamp holder, so you have to change the whole unit. I ordered clear / smoked side repeater lenses yesterday, but found loads of different suppliers of front / rear clear units with quite a large variety of prices. Foundry 4x4 seemed to be one of the cheapest. Any advice appreciated. Cheers.
20th Mar 2011 12:22pm |
Just buy the lenses you don't need the units...i got mine from bolt on bits as a package but the units they supply are not the best, ended up using my old units NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
20th Mar 2011 12:36pm |
If youve got a Puma the lens cannot be separated from the back plate piece. Only the bulb holder can be removed. I got a pair of Wipac rear lamps from www.offroadrovers.co.uk for about £10 plus postage. They have a shop on eBay too.
Pete |
20th Mar 2011 11:07pm |
Sorry Green Machine thats what i meant bulb holders . NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
20th Mar 2011 11:12pm |
No worries - thanks for the advice. I'll have a look at the offroad rovers site - probably get them from there. Cheers.
20th Mar 2011 11:41pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19668 |
Any link available for the LED brake lights at all?
Cheers |
22nd Mar 2011 9:15pm |
