Home > Puma (Tdci) > Towing options |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
The rear step step tow bar has two heights which don't work with some trailers - the two 'adjustable' tow bars give more options but the slider version makes it quick to adjust and change tow balls if you need to. In the past year I've towed a caravan, a motorcycle trailer and a Sankey all of which need the different heights and in the case of the Sankey a different coupling. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
31st Oct 2013 2:55pm |
AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 |
Thanks for the measurement Birdy - I'll do some measuring.
I've got 3 things to tow (horse/car/utility trailers), but mainly thinking adjustable if the standard fitment turns out to be too high. |
31st Oct 2013 3:25pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16943 |
Can't say I've had any more trouble in the last 30 years with sockets mounted in either the PTO hole of Series chassis or the socket hole of current-style chassis, the crossmember recess really doesn't tend to fill with crud, but I do clean out the socket if it's filthy. I have on the other hand had loads of trouble with sockets mounted elsewhere, where the back of the socket is exposed to the elements. Horses for courses, really. It works for me! Also useful to have the correct answer for those who ask what the recess is for. |
31st Oct 2013 5:55pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
Interestingly I asked Alistair at Richards Chassis about that gap and he said it wasn't actually for towing socket, but some military socket or other.
either way I don't have the hole in my x-member, being a tdi, but I just figured it would get full of rubbish/mud. Pretty sure it would on mine. |
31st Oct 2013 6:07pm |
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 |
I regularly tow everything from a twin axle ifor Williams, to a single axle 6m rib, to a single axle small domestic ifor Williams. I never need to adjust the tow ball height. I have a 90 with rear NAS step and a combi towbar/ jaw in the lower holes. Works a treat, no need to remap on the 2.2 when I tow just over 3 tonnes.....how fast are you wanting to drive with all that weight on ? It's all about the braking not acceleration... Sib
Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
31st Oct 2013 7:47pm |
No need for speed when towing - with horses on board you're pretty limited anyway - my gut feeling is that it'll be fine without a remap, but always interesting to hear people's opinions.
31st Oct 2013 7:57pm |
Cadence Member Since: 23 Mar 2015 Location: Beaconsfield Posts: 44 |
I had a factory fit towbar and electrics on the new 110 SW I collected in June. I tow a large garden trailer and an enclosed race car trailer. On my first attempt at towing with the Defender, it was clear that the tow hitch (even with the plate and tow ball on the lowest setting) was way too high.
I believe that EU regs say tow bars should be between 350-420mm measured from the ground to the top of the ball. MyDefender is 550mm! No wonder the trailer looks like it's dragging it's bum. Called the dealer and LR Customer Serrvices both claimed to never heard about this issue. LR wouldn't accept my measurements even with supporting pics showing tape measure evidence. Insisted I go to a local dealer (they didnt sell me the new one) so 'a technician' could measure and confirm. Just returned and waiting for LR verdict. Anyone else had a moan about this? If I'd known it would be an issue I would have bought the adjustable version. if I'm paying for a drop plate to make my new vehicle compliant. My Freelander 2 factory tow bar is spot on at 420mm |
4th Aug 2015 2:13pm |
defendercorner Member Since: 17 Feb 2014 Location: Pembrokeshire Posts: 59 |
Do the EU regs apply to commercial vehicles? 2015 90 2.2 XS Hard Top
2012 110 2.2 XS DC 2003 110 TD5 County DC (now sold) |
4th Aug 2015 3:36pm |
Fair point - I had thought that might be the rational that LR might use - my Peugeot Boxer tow bar is compliant so it's a tough call. I'll do some more research on the web. Cheers
4th Aug 2015 4:31pm |
Just googled it and looks like regs don't apply to 4x4's ? 2015 90 2.2 XS Hard Top
4th Aug 2015 5:49pm |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 |
The regs may not apply but if the tow ball height is too high or low it dose not do anything for the stability or safety of the outfit. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
4th Aug 2015 7:27pm |
biffabacon67 Member Since: 22 Feb 2011 Location: Northumberland Posts: 67 |
Totally agree!! |
12th Aug 2015 3:36pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
The 2" receivers are NOT type approved towing equipment. Correct However commercial vehicles do NOT require type approved towing equipment by law. Therefore an insurance company would struggle to weasel out as the towing equipment you would be potentially using IS LEGAL. 2015 Defenders are all classified as commercial or N1 vehicles with the lower tax rate. Towing electrics? Apparently JLR only offer the 7 pin towing electrics on Defenders. Other vehicles you have a choice of 7 or 13 pin. 7 pin towing electrics are just plugged into a connector in the wheel arch. For 13 pin towing electrics some of the wires have to be taken to the front of the vehicle. Modern caravans use 13 pin so consider carefully what you are likely to be towing. Next carefully compare say cost of tow packet from JLR to main dealer and good indie. Brendan |
12th Aug 2015 10:33pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
13 pin electrics available ?? http://accessories.landrover.com/gb/en/def...ng/towing/
12th Aug 2015 10:38pm |
