Home > Td5 > Aircon extended grill surround fitment?
2hel
United Kingdom 2003 Defender 90 Td5 CSW Java Black
Apologies for being a total newbie here but I recently purchased a replacement aircon grill for my 90 and I notice the fitment seems off? I assume the panel should sit flush with the front of the wings but the grill surround is clashing with the bracket?
Before I go trimming the surround to recess further am I missing something obvious Laughing or is it totally normal and that's how it is...
Here's some pretty poor pics to try and show what I mean
Post #975181 19th Dec 2022 10:03pm
rustandoil
Mine doesn't fit much better 😕
Post #975182 19th Dec 2022 10:13pm
2hel
Well that's good to know Thumbs Up if it's 'normal' then that's good I'll fit the grill and walk away Laughing
Post #975183 19th Dec 2022 10:15pm
rustandoil
I did try to improve mine, but it was hidden behind a soft A bar so didn't bother me too much.... When I refit after junking the A bar it might be a different matter 😂
Post #975185 19th Dec 2022 10:28pm
Dinnu
Mine fits ok. The grille has kind of the profile for the light surrounds, and that abuts the light surrounds and looks right on mine. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #975202 20th Dec 2022 7:16am
That gap is hidden by the headlight surround:
 Darren
Post #975209 20th Dec 2022 9:36am
geobloke
If the AC grill you have bought is after market you might have to trim/file down some of the plastic to make the fit better. I had to do this along the internal edges that run up between the wings and radiator support. It wasn't much but it fits with a better panel gap now.
I presume you have the correct lower fitting brackets as well?!
Post #975217 20th Dec 2022 10:23am
2hel
Yours seems to fit flush at the bottom? Mine is sticking out a bit more, maybe ill try and adjust the bracket before trimming to see if theres any adjustment on that.
Post #975219 20th Dec 2022 10:44am
2hel
The grill is factory according to the people i got it off (Nene overland) and the lower brackets are what came on the car (factory AC). ill have to try and do more tinkering to see what the issue is.. Crying or Very sad
Post #975220 20th Dec 2022 10:45am
nitram17
Welcome to defender ownership Very Happy the bottom brackets probably need a bit of fettling ,beware the originals are made of cheese and rust away in months ....you could fashion your own from ss or buy a lr set from here
https://www.lrparts.net/mtc6332-defender-a...acket.html
or buy a stainless steel set from yrm(a great source of improved defender stuff)
https://yrmit.co.uk/product/s-s-mounting-b...-defender/
Post #975227 20th Dec 2022 12:22pm
There's some more detail here that might help: https://www.defender2.net/forum/post854635.html#854635 Darren
Post #975253 20th Dec 2022 2:56pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Okay so it should definitely fit way better than that. Mine is factory and has always been a perfect tight fit. If you are adding this after market you need to add an extra thick washer (pic I am pointing at) to affix the slam panel to the fenders, which creates a larger gap to slide the grill surround in between the fender and slam panel.
Good luck Thumbs Up
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #975258 20th Dec 2022 3:31pm
2hel
Brilliant thank you, i think you have just persuaded me to order a new fixing kit Laughing
Post #975261 20th Dec 2022 3:56pm
2hel
Good luck Thumbs Up
Thank you ill give that a go! I like the fixings you used for the top of the surround, did they come as part of a set or did you buy separately?
Post #975262 20th Dec 2022 4:07pm
4RF RDS
Just some stainless crews I had lying about in my garage. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #975263 20th Dec 2022 4:16pm
