Home > Puma (Tdci) > 07 plate alarm question |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
This has been covered numerous times in the past so if you do a search all will become clear. In the mean time the best option is to cover the rearward facing volumetric sensor with a bit of insulating tape and then you can use the key fob as normal. This is what I do for when I have the dogs in the defender. Other options are to disable the volumetric sensor with a diagnostic tool which allows access to the 10AS module. Easiest option though is the taped sensor.
Click image to enlarge HTH Brian. |
24th Sep 2011 12:29am |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 |
Easiest option is to just unplug the cable from the back of the unit. Richard
Either a 90, 110 or 130. Discovery 5 |
24th Sep 2011 1:17am |
True, though you will have no volumetric sensors at all if you do that. However covering up the rearward facing sensor means the front one is still functioning and you don't need to remove any trim. Plus when the dogs are not in the back all you need to do is remove the tape to allow full volumetric alarm coverage.
Brian. |
24th Sep 2011 2:34am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5443 |
I thought you just lock it with key, not remote. This sets alarm and immobiliser, but not the volumetric sensor.
Andy |
24th Sep 2011 7:00am |
KeithDawson Member Since: 23 Sep 2011 Location: Argyll Posts: 6 |
Thanks. I have some insulating tape somewhere!
24th Sep 2011 7:20am |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
As Landy Andy says lock with the key and you can leave the sun roof open and the windows down a bit for the dogs and the alarm won't go off unless some one puts their arm in and tryes to unlock the door on the door card, in my case the will also get their hands bitten or licked depending on which one of our mutts i've got with me at the time and its not the way most people think, the Rotty cross is as soppy as and just wants to be every ones friend, the cute looking little Jack Russel on the other hand, you wont be getting in my Land Rover if she is lose in there don't even bother locking the doors if both are in there. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
24th Sep 2011 8:26am |
Sorry, have to disagree with you on that. Have a read of this: http://www.defender2.net/forum/topic5817.html
Click image to enlarge Brian. |
24th Sep 2011 6:09pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Yep, agree with Brian. As far as I'm aware there is no alarm activation when locking with the key alone, the fob has to be used for the alarm to be activated. Similarly, if the alarm was activated with the fob and then someone tries to unlock with the key, the alarm will go off - as has happened to me when other people have gone to get something out of the car!
Edit: sorry Bri, didn't read your above post fully - you've answered the second part of my post as well! Good man! 2005 Td5 | 90 Station Wagon | Tonga Green |
24th Sep 2011 6:33pm |
Green Machine, it may be worth checking too see if someone has either been playing around with the alarm settings or the dealer did not set it up properly in the PDI. The normal is for the "Key Disarm" option being allowed in the 10AS to allow the alarm to be disabled with the key after being set with the fob. IMHO I think this is so you can get the defender going again if the fob battery dies or the fob doesn't work/lost it etc, thus allowing you to disable the alarm and give you the opportunity to enter the EKA code to temporarily get around the passive immobilizer purely as a get you home option. Though "Key Mobilize" must also be allowed for you to do this. Click image to enlarge HTH Brian. |
25th Sep 2011 8:54pm |
Cheers Brian, that's interesting. I just assumed it was an unavailable function i.e the key would not ever disable the alarm. Is that the same for Td5's? I don't have any kind of diagnostics kit, but might ask my mechanic when it's next in for a service later this month. I can certainly see it being beneficial if I ever do have to get into it if the key fob has failed. 2005 Td5 | 90 Station Wagon | Tonga Green |
25th Sep 2011 10:00pm |
The TD5 with the factory fit alarm uses the 10AS module as well so the options will still be available in the settings menu.
Brian. Edit: If it is an after market alarm fitted then please ignore all of above |
25th Sep 2011 10:18pm |
