Home > Puma (Tdci) > Puma 2.4 not starting ..... immobiliser???
Page 6 of 12 <123 ... 567 ... 101112>
johnnyd
No
Martin is your guru here, but things to check are the key fob battery voltage? Has it been replaced recently? How many key fobs do you have programmed for the truck? Is yours a black or green as10 unit? I did research having one repaired if you need the details, I can dig them out possibly, do you have a nanocom or similar? Has this been an ongoing issue getting worse, or just surfaced?
JD 2008 TDCi 2.4 XS CSW
Post #796397 2nd Oct 2019 8:23pm
Crosslanes
United Kingdom 2013 Defender 110 Puma 2.2 CSW Baltic Blue
Hi , yes brand new battery in fob and tested that it’s transmitting and it is, I’ve plugged my launch in and a Bosch kts both won’t communicate with immobiliser module, the 10as is a black box and again all connectors look good . Thanks Paul
Post #796398 2nd Oct 2019 8:29pm
johnnyd
Why is there a new battery in the fob? Did it break with the old battery, ie could replacing the battery mean the fob has lost it’s programming, it still radiates rf if not programmed I believe? Do you have a second fob programmed anywhere? Any signs of water ingress in the as10?
Replacement black units are easier to source than my green one
Post #796400 2nd Oct 2019 8:35pm
Crosslanes
Hi no just changed the battery to try to resolve this fault and did it quickly as recommended, old battery had 2.94volts anyway and no only came with one fob, I never use the fob anyway vehicle is not normally locked, just always starts when you turn the key, it drove fine with no faults just parked it up on Saturday went back to it and no start..
Post #796402 2nd Oct 2019 8:42pm
Crosslanes
Sorry meant to say 10as looks bone dry...
Post #796403 2nd Oct 2019 8:43pm
johnnyd
Hmmmm sounds like a dead as10 to me also, But I am no expert........
Like I say black as10 are easier to get hold of or repair, Martin may be able to advise where best to go, I found a place that could repair my green one for about 50 quid I recall, but turned out to be the dodgy replacement ignition switch.
Post #796404 2nd Oct 2019 8:50pm
Crosslanes
Thanks for all the info, I think the 10as as gone down aswell
Post #796405 2nd Oct 2019 8:52pm
johnnyd
Let us know what you discover, always good for reference......good luck, it’s horrible when it won’t start, happened to me twice in France which was a nightmare, and a few times here in the uk, really put me off the truck, but since Martin fixed the fault it’s been perfect.......
Post #796407 2nd Oct 2019 8:56pm
Crosslanes
Will do.. ours is a 2.2 so don’t know if what Martin sent you will work for me? But if you still have the details could you pm them I’ll tray anything at this point
Post #796409 2nd Oct 2019 8:59pm
johnnyd
Martin sent me bypass details which don’t work on the 2.2, but I will try to find my source of replacement as10 modules Tomorrow for you, I don’t have the info with me tonight. But if the as10 has failed, nothing will help apart from replacement or repair 😫
Post #796412 2nd Oct 2019 9:07pm
Martin
Site Admin
I don't think any of the aftermarket diagnostic kit will communicate properly with the later black ALM unit: https://www.defender2.net/forum/topic68425.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #796425 2nd Oct 2019 9:35pm
johnnyd
The as10 repair/replace guy is called Paul Brown......
I have DM'd you his contact details.
Good Luck
Post #796499 3rd Oct 2019 8:53am
johnnyd
Crosslanes did you get to the bottom of this?
Just curious.
Post #800156 31st Oct 2019 8:38am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
That's not true. The Nanocom can do it. But the function is only available as a beta version. Its final release shall follow soon ...
Post #800533 2nd Nov 2019 10:52pm
Martin
Site Admin
Very recent and as you say it’s still under development.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #800540 2nd Nov 2019 11:15pm
