Home > Puma (Tdci) > Puma 2.4 not starting ..... immobiliser??? |
Crosslanes Member Since: 02 Oct 2019 Location: Stafford upon avon Posts: 10 |
Hi , yes brand new battery in fob and tested that it’s transmitting and it is, I’ve plugged my launch in and a Bosch kts both won’t communicate with immobiliser module, the 10as is a black box and again all connectors look good . Thanks Paul
2nd Oct 2019 8:29pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Why is there a new battery in the fob? Did it break with the old battery, ie could replacing the battery mean the fob has lost it’s programming, it still radiates rf if not programmed I believe? Do you have a second fob programmed anywhere? Any signs of water ingress in the as10?
Replacement black units are easier to source than my green one JD 2008 TDCi 2.4 XS CSW |
2nd Oct 2019 8:35pm |
Hi no just changed the battery to try to resolve this fault and did it quickly as recommended, old battery had 2.94volts anyway and no only came with one fob, I never use the fob anyway vehicle is not normally locked, just always starts when you turn the key, it drove fine with no faults just parked it up on Saturday went back to it and no start..
2nd Oct 2019 8:42pm |
Sorry meant to say 10as looks bone dry...
2nd Oct 2019 8:43pm |
Hmmmm sounds like a dead as10 to me also, But I am no expert........
Like I say black as10 are easier to get hold of or repair, Martin may be able to advise where best to go, I found a place that could repair my green one for about 50 quid I recall, but turned out to be the dodgy replacement ignition switch. JD 2008 TDCi 2.4 XS CSW |
2nd Oct 2019 8:50pm |
Thanks for all the info, I think the 10as as gone down aswell
2nd Oct 2019 8:52pm |
Let us know what you discover, always good for reference......good luck, it’s horrible when it won’t start, happened to me twice in France which was a nightmare, and a few times here in the uk, really put me off the truck, but since Martin fixed the fault it’s been perfect.......
2nd Oct 2019 8:56pm |
Will do.. ours is a 2.2 so don’t know if what Martin sent you will work for me? But if you still have the details could you pm them I’ll tray anything at this point
2nd Oct 2019 8:59pm |
Martin sent me bypass details which don’t work on the 2.2, but I will try to find my source of replacement as10 modules Tomorrow for you, I don’t have the info with me tonight. But if the as10 has failed, nothing will help apart from replacement or repair 😫
2nd Oct 2019 9:07pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6489 |
I don't think any of the aftermarket diagnostic kit will communicate properly with the later black ALM unit: https://www.defender2.net/forum/topic68425.html 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Oct 2019 9:35pm |
The as10 repair/replace guy is called Paul Brown......
I have DM'd you his contact details. Good Luck JD 2008 TDCi 2.4 XS CSW |
3rd Oct 2019 8:53am |
Crosslanes did you get to the bottom of this?
Just curious. JD 2008 TDCi 2.4 XS CSW |
31st Oct 2019 8:38am |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 421 |
That's not true. The Nanocom can do it. But the function is only available as a beta version. Its final release shall follow soon ... |
2nd Nov 2019 10:52pm |
Very recent and as you say it’s still under development. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Nov 2019 11:15pm |
